Upgrading to new phone with Bluetooth 5.3
Dan's Lightning
Dan
Victoria BC Canada
F150 Lightning Lariat Extended Range
Previously I had a Samsung S21+ uses Bluetooth 5.0 and was using it with the Ford Pass app for Paak (Phone as a key).
I had many connectivity issues with the older Bluetooth 5.0
-Unlocking by touching a door handle most times took a few seconds or longer to unlock and some times would not even work and I had to turn off Bluetooth and turn it back on for it to be able to unlock the door.
-Locking the door by the one touch bottom would be hit or miss, most times not working and some times taking 3-4 seconds or longer holding my thumb on the touch button, must time I had to walk away with out it ever locking.
-Once inside the Lightning to start the truck, foot on break and hit start button, key not found and the master start code comes up on the main screen.
Often I had to turn off Bluetooth on my phone and re start it to get it to work, even still after re starting Bluetooth took a bit before the lightning connected to the phone to start the truck.
-While driving taking a handsfree phone call the call would be garbled and not functionable.
-With the new Ford pass app version connected controls (open frunk and tail gate) would be disconnected and would never work.
I upgraded to a new Samsung S24+ with Bluetooth 5.3 and now Paak works flawlessly!
-Locks open instantly! the moment you touch the door handles.
-Doors lock instantly! the moment you touch the lock touch pad with your thumb. Night and day difference! Now this is what I'd expected the lightning to do from the beginning !
-Starting the truck with Paak is now flawless and instant.
-The connected app controls (open frunk and tail gate) always work!
-I haven’t tested a hands free phone call yet but I'm very hopeful this is the solution
I highly recommend getting a new phone with Bluetooth 5.3 ! Thought I share my experience..
Henry Ford
I have an S21 but haven't experienced nearly the troubles you describe. However, my wife has an S21+ and has constant issues with her Navigator. Maybe a new phone would solve the problem.
The Weatherman
Dean
South Central KY
I carry an Apple 12 mini and have the exact same experiences you described.
Thanks for posting, I’m sure I have the same issue.
Labs4Lightning
C
@Dan's Lightning
glad things are working better for you.
doubtful 5.3 itself was the cure alone - could have a been a phone specific issue or Samsung bad codec or radio chip - especially with a large number running same phone without issue,
also Ford, like most manufactures are looking for cheap, so they tend to use slightly older technology. (For example think of the money the saved by using old processor for the big screen - lag blows!) that plays across most components, doubtful truck is even using Bluetooth 5.0
though the Bluetooth consortium be awesome, and 5.3 might be better written for backward compatibility.
I recently upgraded from S10-e to S24-ultra, though I didn't have problems with PAAK on the old phone, but I did have issues with phone calls, the few that I've received/placed recently with the new phone have been good.
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
I also recently upgraded from an S10 where everything worked pretty well except phone calls.. I would have to pull it off the Charge pad and sometimes I could here the caller but they couldn't hear me... Now with a new S24 Ultra calls work even on the Charge pad...
Vcrpromo
Victor
San antonio tx
2023 ford lightening
I have a samsung fold 5 with 5.0.and never have problems.
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
My 12 pro max has the same issues. If my phone is in my pocket furthest from the truck, it wont detect my hand and open the truck. I have to turn my body or hold my phone close to the truck so the door handle can sense my hand.
