Upper Balljoint Replaced??
Garyl
Somewhere
I was looking at a 2025 Lighting with a little over 1000 mile on the odometer. The Carfax reports that the upper ball joints were replaced. I don't remember any recalls on them. Any thoughts?
my driver rear axle was replaced, back about 40,000 miles in... it was simply my noticing a substantial amount of 'dry grease' sprayed all over/around the suspension area, probably from a split/leaking grease boot.
Ford replaced it with a new axle, at no cost, since it is part of the 'powertrain' coverage up to 8years/100,000 miles... they can't simply replace a boot, they replace the whole 18"-24" axle, with new boots integral on both ends.
I would not be concerned with it.
inchman254
Collingwood, Ontario, Canada
F150 Lightning Lariat, Kia Telluride
Issue: On certain F-150 Lightning (electric) trucks, the nuts for the ball joints that connect the front upper control arms to the steering knuckles may not have been properly tightened. As a result, the upper control arms could separate from the knuckles. If this happens, there could be a loss of steering control. Safety Risk: A loss of steering control could create a risk of a crash. Corrective Actions: Ford will notify owners by mail and advise you to take your vehicle to a dealership to inspect for loose and/or missing nuts. If any loose or missing nuts are found, the dealer will replace the steering knuckle(s) and nut(s).
printer1443
Angelo
Hamilton, Ontario Canada
2023 XLT ER Antimatter Blue
Self Employed
I just had one of mine replaced, the teck thinks that maybe it didn't get greased when they built my truck. They had a tremor in a week prior with the same issue and it has the same part as the lightning. Mine is a 23my.
