No, there is no way to lock the FCSP. Once it's enabled, anyone can plug in and use it.My charger is outside my house. Is there a way to at least lock to prevent usage by someone while i am not at home?
The FCSP does not require internet access to function. Once it's powered up, it's usable by anyone.I don't believe someone other than you can use your charger. That person would have to have the station added to their account by using your wifi connection. So unless your home internet is not secured or you share access in the app it shouldn't be a problem.
Hum... so you are saying setting it up in the app was just to enable stats? I could have just plugged it after installation and it would charge the truck?The FCSP does not require internet access to function. Once it's powered up, it's usable by anyone.
That is correct. Internet access provides stats and firmware updates.Hum... so you are saying setting it up in the app was just to enable stats? I could have just plugged it after installation and it would charge the truck?
Great post. People make up names without understanding there are multiple chargers. In addition, there is the Ford Connected Charge Station (48amps) and the Ford Mobile Charger (32 or 30amps depending on the vehicle it came with).You use the term “pro” in your question, but there are two different Ford-branded “pro” charging solutions.
The Ford Charge Station Pro is a consumer-level 80A charging station. This does not allow you to control access to the EVSE without either flipping the breaker or putting on some kind of lock.
The Ford Pro AC Charging Station is a fleet-level 48A or 80A AC charging station. This allows RFID-managed charging, but is typically not intended for consumers.
No, there are not.Well I learned something today. Are all EVSE the same?
I thought the FCSP was considered a smart station. My question was more about the capability of locking a station.No, there are not.
Some are faster (up to 80amps), some are 48, 40, 32, 24...
Some have intelligence and data. Some are dumb. Many intelligent EVSEs allow you to lock them (software) quite easily.
