B177y
- First Name
- Bill
- Jul 16, 2024
- Olympic Peninsula, WA
- '24 Pro SSV ER Max Tow, '23 MME Premium, '20 Bolt
New 2024 Lightning Pro SSV ER, 7/2024 build date, small screen (not the 15-inch screen). I have searched the various Walk Away Lock (WAL) threads, but they all seem to be about how to enable the WAL switch in the Sync menu. I have the option in my settings menu, but I can't get it to enable. When I touch "enable" a popup message shows with "That option is not available right now. Please try again later." I have done various "later's"... 1 hour, 2 hours, 24 hours, etc... but still get the same message.
I followed the advice of the Forscan threads on how to enable WAL, and in the "simple" APIM menu, WAL already shows as "enabled".
The FDRS guru's (@Mike G and @rugedraw ) ran my VIN and I have no substantial updates available. There are DDM and PDM modules available for update (Driver Door Module and Passenger Door Module), but from other threads and sources, the APIM and BCM are what controls the WAL, so these should be unrelated.
So the questions:
-Is WAL available in a Pro trim?
-Is the message "try again later" accurate or is this similar to Ford's "Soon" (ie...never)?
-Does anyone else have a similar issue and did you get WAL to work?
So the questions:
