ericpullen
Eric
Louisville, KY
I'm happy to announce a new Python based library for the Ford Charge Station Pro.
https://github.com/ericpullen/fcsp-api
[Update 2025-06-30]
It is also available as a PyPi package as well:
https://pypi.org/project/fcsp-api/
Currently the library can authenticate and get the basic information allowed by the local API (charge state, max amp setting, station ID, and a few other minor details). The big thing here is we can use it to see if something is plugged into it, if it is charging or not, when it is disconnected, or when a charge error occurs.
You will need to understand the basics of using Python to run this, but its pretty straight forward. There are 2 example apps, one that gives you a bunch of charging info and test some various state functions (fcsp_charging_state.py) and another one that simply polls the FCSP to see what the current state is and report to the screen when it changes (fcsp_state_monitor.py).
Here is an example of the fcsp_state_monitor.py:
Bash:
epullen@EricsM4MegaMini:code/fcsp-api ‹main›$ python examples/fcsp_state_monitor.py
? FCSP State Monitor
? Polling every 30 seconds
? Press Ctrl+C to stop
? Getting initial state...
? Initial state: ? CS02 - Charging
? Starting monitoring loop...
I'm going to continue looking at the internals of the FCSP, but this should give people a great starting point to look deeper at what the local FCSP api can offer. If you want to contribute code, please just create a pull-request and I'll take a look at it.
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
Not sure which place you'd like me to put this. BUT.
There seem to be two different statuses from the API.
1) Within get_status() which seems to hold charging_state values of "CE012" or "CS010" - I've seen both in logs. I don't know what these are for or how they seemingly relate to the unit.
2) Within get_charger_info() which seems to hold the same state values of "CS00", "CS01", and "CS02" listed above to denote charging status.
INTERESTINGLY, "CS02" is regardless of direction of power transfer. I tested this with my HIS, and the state field gave me "CSO2" when the power transfer began.
I've taken @ericpullen's foundation and tried to build an HA integration into it. So far, I'm seeing most of the info already discovered, but nothing yet regarding power transfer currents.
I've also seen something a little fun - get_wifi_networks() should not be used unless you actually want to scan for WiFi networks. I accidentally got it going into the 'white' LED scanning mode. Thinking about it, it did exactly what I wanted it to do ;) But I wasn't ready for it lol ;)
ericpullen
ericpullen
Eric
Louisville, KY
All of the status messages were just discovered by testing various changes to my FCSP. Since I don’t have HIS, I can’t really test it, but not surprised they just used that same status code for power going in or out.
One thing to note, the FCSP actually has 2 processing units built into it. The one I’m hitting is the generic TI embedded system and is the one you can see on the P3 UART. The other one is some Siemens embedded system that doesn’t look like Linux, but is some other Versicharge S7 PLC. Not sure it’s worth going too deep on that one, other than to try and read data from the RS485 at some point.
Pacific.NW
Christian
2022 Lightning Lariat ER
I don’t have an FCSP, but just wanted to hat-tip for your work!
Aminorjourney
Nikki
Internet
This makes sense. So we're pulling most of the data from the TI Embedded system.
I'm hoping I will *soon* be able to put a passive HA integration together that can hit most of the sensible info, and I have captured three separate state IDs for the HIS inverter.
It seems to sit at 0. If a backup session starts, it switches to 1, and then when everything actually starts transferring power, 5.
In *other* cringeworthy stuff, did you notice that the API not only puts out the ID of the station but the password you need to access it? That has to be a massive security flaw.
ericpullen
ericpullen
Eric
Louisville, KY
If only they had a massive security flaw for the ssh implementation so I can get in and poke around at the python code they have written. ?
Aminorjourney
Nikki
Internet
Ha! Right!
I have the basics of a very basic HA integration that *should*, by the end of the week, be installable via HACs... I do need to bundle your fcsp_api though, unless you're willing to make it available on pypi or elsewhere so I can list it as a dependency :)
That said, I'm very very inexperienced and an autodidact, so I'm sure someone smarter can do it quicker ;)
rgrandy
Ha! Right!
This is great! I'm just getting my lightning HA dashboard setup and would love to add this!
ericpullen
ericpullen
Eric
Louisville, KY
I think I can get it up on PyPi, let me look at that today.
ericpullen
ericpullen
Eric
Louisville, KY
Ha! Right!
Here is the pypi project:
I noticed the Installation steps on both your git and pypi say:
Code:
git clone https://github.com/yourusername/fcsp-api.git
Shouldn’t that say “ericpullen” instead of “yourusername”?
I realize most folks would figure it out.
ericpullen
ericpullen
Eric
Louisville, KY
Code:
Shouldnt that say “ericpullen” instead of “yourusername”?
Thanks, missed those. Its been fixed!
Aminorjourney
Nikki
Internet
Ok progress.
I’m not happy to GitHub yet but soon.
I relied quite heavily on the cut and shut method of programming, and I also need to get an icon… BUT.
It’s getting there ;)
Ford F-150 Lightning New FCSP API Python Library (fcsp-api) IMG_7837
Ford F-150 Lightning New FCSP API Python Library (fcsp-api) IMG_7836
Ford F-150 Lightning New FCSP API Python Library (fcsp-api) IMG_7838
Ford F-150 Lightning New FCSP API Python Library (fcsp-api) IMG_7839
