WildBlue
I just finishing installing my FCSP on a 100a circuit. During the install, I decided to set the amperage switch inside the unit to 64a instead of the default 80a. I did this because I have another EV at the house and wanted to make sure I don't overload my 200a service if both vehicles happen to be charging at the same time. That being said, I didn't realize the software through FordPass can apparently set the amperage limit in 2a increments with a large range. So now I am wondering if I should set the hardware switch back to 80a and limit the current in software to 64a (or another amperage I deem necessary). Is this how it's supposed to work? Does the hardware switch limit the upper threshold of the software (IE the 64a limit will override any software current settings above 64a)? Just curious to know how the hardware and software limit interact with each other. Thanks!
