Administrator
Administrator
Staff member
Purple State
F-150
Admin
Via Ford:
Ditch the Extension Cord Spaghetti: An Easier, More Affordable Way to Power Your Home
July 22, 2026
Ford F-150 Lightning GenerLink Transfer Switch Compatible With 240V Pro Power Onboard Outlet -- Ford Announcement ford_generlink_13
Texas' 2021 winter storm changed how Kenneth Kovar thought about backup power.
His home in New Braunfels, Texas, held onto power that time, but the scare stuck with him after he was without water for multiple days. The thought of his family, including his daughter and her family, losing power for days with no safe, reliable way to run essentials like a hardwired septic tank kept him up at night.
"If we lost power and my daughter lost power, I wanted to be able to provide a place for her to stay as well," he said.
He wanted a real plan in place that didn't depend on gas cans or hoping a generator started when he needed it most: "It's just so much easier if I've got a truck with a plug."
A Port in the Storm
Kenneth isn't alone. And for customers in rural communities, the stakes are often higher. A well pump, a septic system, or a sump pump isn't a convenience; it's the difference between a livable home and a real emergency.
As power outages become a more regular part of life for American households, we've watched customers rely on Pro Power Onboard® — running a spaghetti of extension cords to keep a few essentials powered.
Extension cords can keep a fridge running, but they can't power what's wired into your walls. The challenge has never been the power; it's getting that power into your home simply, reliably, and affordably.
Ford F-150 Lightning GenerLink Transfer Switch Compatible With 240V Pro Power Onboard Outlet -- Ford Announcement ford_generlink_7
That's why we partnered with Global Power Products to bring the GenerLink transfer switch to Ford owners.
GenerLink uses technology that's been proven in the market for more than 20 years with portable generators — and now, it's compatible with Ford's 240V Pro Power Onboard outlet.
When paired with an F-150 PowerBoost™ Hybrid with 7.2kW or F-150® Lightning® with 9.6kW with 240V Pro Power Onboard outlet, it eliminates the tangle of extension cords needed to power individual home appliances.
Instead of running cords through cracked windows and doors, you can now run a single connection between your truck's 240V Pro Power Onboard outlet and a GenerLink transfer switch installed at or near your utility meter.
That switch energizes your home's main electrical panel, so your lights, Wi-Fi, gas furnace, outlets, security system, and other hard-wired essentials can run the way they normally would, within the wattage limits of your home and vehicle.
So how long can that power last? It varies by usage, but it’s estimated that 2021-2026 F-150 PowerBoost Hybrid and 2022-2025 F-150 Lightning trucks that are equipped with 240V Pro Power Onboard outlets can provide power to an average home for up to five days (2021-2026 F-150 PowerBoost Hybrid) and up to two to three days (2022-2025 F-150 Lightning Standard/Extended Range) using the Pro Power Onboard feature.1
Ford F-150 Lightning GenerLink Transfer Switch Compatible With 240V Pro Power Onboard Outlet -- Ford Announcement cqdam.web.2400 (5)
This is the kind of practical innovation we're proud to bring to market. After piloting the product in several states, we're helping expand GenerLink availability to Ford owners — taking Pro Power Onboard, a feature some customers already own, and making it more useful in the moments that matter most.
The Engineering Behind the Simplicity
Making this work requires engineering collaboration and extensive testing.
Plugging a generator-style outlet directly into a home panel can trip a truck's built-in safety sensors, cutting power unexpectedly.
To solve that, we worked with Global Power Products to develop a 12-inch cable, the Ford Vehicle Connector, that ensures electricity has one connection between the vehicle and the home.
It's a small component with an outsized job, helping keep the system reliable and simple for our customers.
Ford F-150 Lightning GenerLink Transfer Switch Compatible With 240V Pro Power Onboard Outlet -- Ford Announcement ford_generlink_3
How It Comes Together
Installation depends on your local utility's requirements. Some utilities manage the installation themselves, and others will require a licensed local electrician.
  • Meter-Mounted: More than 800 utilities across the U.S. currently approve GenerLink for direct meter installation. The equipment bundle — GenerLink transfer switch, GenerLok cord, and Ford Vehicle Connector — runs around $1,100, with estimated installation typically averaging $250 to $450.
  • Meter Adjacent Mounted: If your utility hasn't yet approved meter-mount installation but permits installation of other types of transfer switches, there's still a path forward. The equipment cost remains around $1,100, but installation is more involved, estimated to average $1,000 to $1,500.
We are continuously working to help make meter-mounted installation available in more markets. Check out the link to learn more about your local utility's requirements.
Ford F-150 Lightning GenerLink Transfer Switch Compatible With 240V Pro Power Onboard Outlet -- Ford Announcement ford_generlink_16
Straight From the Driveway
For Kenneth, that peace of mind is no longer hypothetical. The next time a storm rolls through New Braunfels, he won't be checking gas cans or hoping a generator starts. He'll plug in and use Pro Power Onboard.
The essentials that keep his household running can stay running from the truck already in his driveway as he hosts his daughter’s family from down the road.
That's what Pro Power Onboard and GenerLink make possible — not just for Kenneth, but for anyone who's ever watched a storm roll in and wondered if the lights, water, or heat would stay on.
RipInPepz
Erik
Ohio
2025 Flash Antimatter Blue - 131kWh ER, 9.6kW PPOB
Waste of time and money. A simple generator inlet box and interlock kit is all you need. Leave the ground disconnected inside the inlet box, so the ground fault protection doesn't trip on the truck because of the bonded neutral.
"Plugging a generator-style outlet directly into a home panel can trip a truck's built-in safety sensors, cutting power unexpectedly."
^ This is nonsense, accommodating to the lowest common denominator. I've powered my whole house numerous times, for hours or days on end. Approved by my buddy who is a master electrician. You just want to make sure you leave a note on the inlet box saying that if someone plans to use this with a regular generator, to connect the ground inside.
josh27292
Josh
North Carolina
2023 Lightning ER
Question, I currently have a interlock transfer switch that I can't use for my Lightning because it ground faults which I assume is because both ends are bonded. Would this work for my situation?
Lake Placid Lightning
2023 Lariat SR w/510A
Civil Engineer
It would, or you could simply remove or disconnect the ground wire from one end of the extension cord that you use between your Lightning and the transfer switch.
Eliminating the ground in the cable used only between the Lightning and transfer switch has been discussed previously in this thread: https://www.f150lightningforum.com/...ole-home-interlock-question.28295/post-528704
Electricians may not approve this method, but it works.
You could also install a neutral switching sub-panel that allows you to retain GFI protection.
21st Century Truck
Martin
I made an 18-inch whip with male and female bolt-on plugs, and cut the ground within the whip. This whip stays on the truck at all times. This way, the generator inlet plug on the house remains always safe for any type of power hookup, with me present or not present.
ClevelandBeemer
Ironic that the Ford solution is to simply not connect the ground on the Generlink. 🤣
I am curious about this statement and the picture of the 12" cable.
"To solve that, we worked with Global Power Products to develop a 12-inch cable, the Ford Vehicle Connector, that ensures electricity has one connection between the vehicle and the home.
They make it sound like it was some grand electrical engineering feat. But I wonder if they simply disconnected the ground. Or is there some embedded electronic device that prevents the truck's GFCI from tripping while preserving ground.
If so, it would be nice for all the interlock folks if they could just order the 12" cable.
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
Interesting - I wonder what happens when you throw an installed solar system in on top of all of this ... :unsure:
Interesting indeed; there must be a means to ensure the solar system doesn't try to feed power into the truck's inverter, tripping a breaker if you're lucky and damaging something if not.
My home has a non-battery solar array with microinverters and a utility-supplied transfer switch that looks very similar to the GenerLink. When we connect the truck, we turn off the solar system with a big manual switch. A more sophisticated solar system which can run off-grid would need a dedicated generator input; perhaps the experts on the forum can explain how that would work. Probably a bit pricey, but the ability to run long-term off-grid seems awfully nice.
OregonMike
Eugene Oregon
24 Flash
I just ordered mine yesterday. I had to call them to get the Ford adapter and they hit me for another $100 for that. I found a $100 off coupon online (inpower) so it was a wash. My electrician said it should be a one hour charge but we'll see in a week or two after it gets here.
ryun
Earth
I'm not going to pretend I'm an expert at this, but how it's been explained to me is that that ground wire is important to cover the scenario in which a massive current goes over the neutral line connected to the truck from the house panel. If you've isolated your neutral in your circuit just to the truck then the only power ever going over the neutral/ground is the stuff generated by the truck -- so it can handle it. Our homes might have a significantly higher wattage fault for whatever reason. And since our trucks have a bonded neutral-ground there's no way to redirect it away from the truck.
So this is a CYA product if it's properly implemented I believe. If you care about that peace of mind then it's worth it.
For what it's worth I don't think you're wrong, but if I had this option I'd probably pick it up myself. Unfortunately my utility doesn't allow it yet.
Edit - Well, given that posters have proven it's just a cable with the grounding wire removed there goes my theory. (n)
ryun
Earth
Really instilling confidence here lol :rolleyes:
Ford F-150 Lightning GenerLink Transfer Switch Compatible With 240V Pro Power Onboard Outlet -- Ford Announcement 1784748407594-25
Would you mind using an ohmmeter to check continuity on the 12-inch adapter cable to see if the ground is lifted? The ground is the one with a little hook.
Ford F-150 Lightning GenerLink Transfer Switch Compatible With 240V Pro Power Onboard Outlet -- Ford Announcement 1784756343720-0x
