mhoffman54
Matt
Minneapolis
2021 F-150 XLT (302A), 2016 Harley Davidson Sports
Car Sales Consultant
My build date was 04/21.
playing around with the FordPass API the following OTA info is available. Seems like for me 1.7.1 was cancelled for some reason. See below;
Yup. Your 1.7.1 is stuck. Shows as "Pending". Have you tried manually updating it in Sync 4?
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1639778141718
The same update was successfully downloaded and then cancelled on 12/11.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1639778264999
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1639778293177
abd79
Wayne
2021 F-150
I’ve done a master reset and basically started from scratch. My auto update and notifications can’t be enabled, the schedule can be set but then reverts back to undefined on its own and when I click on update status it says it’s checking for an update but then comes back saying I’m up to date.
heffer86
Iowa
2021 F150 Lariat 501A
Are these screen just dealers can see? I'd be willing to pay for a subscription to see this data.
Jesse-Infotainment
2024 F150 Lightning Platinum
Well, I just tried that. Can't re-activate it at all now.
When I enable debugging it shows a cellular connection too. Doesn't make sense, and confirms to me that it's software related, not hardware.
Just give it some time. Sometimes it takes a bit for the removal to be completed.
you can also do a master reset in the apim if you want.
Jesse-Infotainment
It’s in dealer level oasis. I have oasis but for me to see any of the connect data I would need permission. It would send a code to the user email association with the truck and I would need that code. Dealer level access doesn’t need permission. This would let you see any DTCs or codes without even plugging into the vehicle. Shows how many miles and even fuel level.
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
The best thing you can do is get your truck fully updated now. There were MANY updates for early build trucks for modules that I believe to be not OTA capable.
Just curious, and this will probably get from dealer to dealer, but would getting these updates applied have a cost, or would it be almost like a warranty item? As much as I want the updates, I really don't feel like paying a dealer to apply them.
Jesse-Infotainment
I can’t speak for the dealer BUT these are considered requirements for the trucks functioning. These updates aren’t to add features they are to improve experience and existing functionality.
they should NOT charge you especially in warranty. The reason I say I can’t speak for the dealer is because we all know there are always those dealers that are just ignorant and don’t want to mess with this stuff.
heffer86
Iowa
Have you gotten yours to work with the connected data? I paid for the two day subscription to the OASIS reports. I sent sent myself the email. I received the code and it ran into a error every time I tried tied with my co-works 21 too and same issue. Received the access code email and failed multiple times. Tried all the different browsers too. No luck
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
Dear Guys,
I owned 2021 502a Lariat F-150. I live in middle east in Kuwait. I have many inquiries but the first one is that the "Manage wifi networks" is not appearing in SYNC 4 Connectivity menu!?
I don't know how to update my system because I can't connect to wifi.
any help well be appreciated.
Software version: 21136
Revision: 134
Jesse-Infotainment
No I haven’t tried.
I have a dealer level access that is available to me but I use it EXTREMELY sparingly.
Jesse-Infotainment
Dear Guys,
Revision: 134
Looks like based on your sync version you have a July august build. Maybe later. It’s the version right before 21223. You’re most likely up to date as far as OTA goes. Is yours a actual ME build or a North American build exported to ME.
Also updates will go through independent of Wi-Fi
ENG430
Ahmad
Kuwait
Its actual ME build.
May I know how to update the system?
Jesse-Infotainment
Thanks... You basically confirmed all my suspicions.
Do you know the calibration version required for the IPMA?
I recently updated mine with FRDS.
Code:
IPMA - Image Processing Module A
Part number: ML3T-14G647-FK
Calibration level: ML3T-14G647-FK
Strategy : ML3T-14H102-ACA
Calibration: ML3T-14H103-AAF
I'm pretty sure that once ford releases the next power-up for the APIM (post 1.7.1) that we will hopefully be able to use the cams in motion.
Part number: ML3T-14G647-NA
Calibration level: ML3T-14G647-NA
Jesse-Infotainment
Here is a video of the truck as it is now
Jesse-Infotainment
You can only update these through FDRS or OTA.
FDRS is the Ford Diag tool.
