TJSparky
Thanks Iceman. Any tips to jumpstart it? Like I said before I’m just leaving the USB stick in until I get some kind of notification like others eventually got.
It could also be that the modules Ford updated OTA and the ones you updated manually didn’t have FORScan changes to them that were overwritten. Double Honk was BCM. Digital temps are IPC. I don’t think software changes have been made to either module recently, by Ford or us.I only had minor Forscan changes previous to the host of updates I applied. Double-honk & dash gauge temperature values.
I did not lose either change. I did them months ago, so your explanation sounds accurate.![]()
A really good "mechanic", someone with experience and the natural talent for diagnosing and repairing your internal combustion engine, transmission, clutch, brakes, differential........ I mean a real deal guy...... Can you imagine him being the same guy with this skill set? Or even wanting to be?After seeing the time and patience these updates take it is no wonder dealers either don't know or don't want to deal with this.
How can this be done? Where is there a road that straight without giving any steering input?NOTICE: Your truck may exhibit a Reverse Brake Assist Unavailable message after module programming has been completed. This may be due to a network interruption from programming or configuring modules, which can cause steering center find to be reset. When the steering center find is reset, this causes various features to become disabled. The steering center find can be relearned by driving the vehicle approximately 5 minutes above 18 mph (30 km/h) straight ahead on a flat surface with no steering inputs for a few seconds. When Steering center is found the Reverse Brake Assist Unavailable message will go away.
I left it in and was driving around with it. There is no harm doing soQuick for those of you that had issues getting APIM to update. Did you just leave the USB plugged in and operate your truck like normal? Or did you park and leave it on accessory mode?
Set it and forget it, I can do that! Thanks!I left it in and was driving around with it. There is no harm doing so
