TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Iceman did you still use the radio and other Sync4 screen controls while driving/waiting for the USB to kick off or did you leave everything off?
RapidRedRick
Rick
Northern Virginia
Ford F150 Platinum Powerboost
My F 150 was built in March 2021. I got the truck in Sept 2021. My Sync4 Software Version is 20312_PRODUCT Revision:243 and I have never had an update message the entire time I have owned the truck.
If I have read the tread correctly, it sounds like I am going to have to update the gateway modem (GWM) before any OTA updates will occur. Is it possible to get a thumb drive with just the necessary files to update the GWM?.. and then see if the updates for the APIM, TCU and other modules come in OTA?
Jesse-Infotainment
2024 F150 Lightning Platinum
No. The updates manifest is specifically for the truck.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
So, I guess I'll be ordering the patch cable and reformatting a couple USB sticks to exFAT. I'm tired of not knowing what's going on and having Ford just tell me to 'be patient' or 'it's OK,the truck will update on it's own if needed'.
Yea, right... Hope I don't brick my truck!
I shouldn't guarantee that you can't "brick" something doing this with FRDS, but I don't think the probability is very high.
Just have the truck on a charger, make sure your laptop is stable and plenty of battery power and you shouldn't be vulnerable.
The only other aspect that could potentially come into play is an internet interpretation, but that would not be in play during the actual write to the module since FRDS doesn't attempt to write until after the necessary files have successfully been downloaded.
Personally I don't think anyone could possibly know or decipher how many updates their truck is eligible for. So many of my updates had nothing to do with what version of Sync I was on.
Gear Shift module?
Audio control module?
Here is a list of the first scan of my truck and the list of updates it was eligible for after reading the 40 modules.
Note that list does not even represent updates that become eligible AFTER you perform the listed updates!
OTA is obviously not performing at 100% efficiency. ?
Jesse-Infotainment
One thing to also know is OTA is limited to the modules on the ethernet. So other modules also have updates that are not even apart of the OTA.
This is another reason why its important to keep the truck up to date. Especially for job 1 trucks and early build trucks.
Snakebitten
Coastal Texas
Ahhhh. That explains that!
I have the factory service manual. I suppose it will clear up which modules are available over ethernet and which aren't?
What's amazing about that is how would a customer ever know that there is an update for the driver's seat module? (for example)
When I performed the update it was obvious the module was being updated, but I have no way of knowing what the update actually addressed? Lol
Jesse-Infotainment
I understand. That’s what I find as stupid on fords part. They aren’t working with their dealers to know about the importance of the updates and treating them with importance.
There have always been updates for modules for fords. the 2021 was sold though as having updates. IDS had a way to update also. It was stupid but it was there. So I think since ford has advertised updates more people are looking for them and rightfully so. I have always plugged into my cars and checked for various updates in IDS.
ethernet units gateway, tcu, ipc, apim, ipma, B&O amp.
mend of day it’s best these days that you have the access to do it and keepup with the updates yourself. For the money you need to spendit’s worth it: when I first was talking about it I knew the cost made it hard. With iceman finding thisaffordable option it really made this a no brainer.
BlackSheep
Indiana
Tools you will need:
- Windows PC with 4GB RAM or greater, running Windows 10 natively (Macs running Windows bootcamp or other VM based solutions are known to cause issues)
- VXDIAG VCX Nano interface (can be purchased from Amazon here)
- USB Flash drive 32GB or larger (must be formatted to exFAT)
- 12V Automotive Battery Charger/Maintainer (I used this one from Amazon)
Software you will need:
- VX Manager (installs driver for your VXDIAG VCX Nano device)
- Ford Diagnostic & Repair Software (commonly known as FDRS)
Software installation (step-by-step):
1) Download the latest VX Manager installer from here
2) Start VX Manager installation, when prompted select PASSTHROUGH - J2534
DO NOT SELECT FORD/MAZDA - IDS. Using this IDS emulation can brick your ECU during the update process (learned the hard way)
3) Connect VCX Nano device to your PC using the supplied USB cable and launch VX Manager. The tool should recognize the device. If there is a device firmware available, update the device firmware
4) Download and install FDRS software from here. You will need a license to run this software and can be purchased here (2-day FDRS license cost $50)
5) Launch FDRS, you will be prompted to enter the license that you have just purchased. Login using your credentials created on Motorcraft website. Make sure you select Non-Dealer Motorcraft as User Type
6) Connect your VXC Nano device to your truck's ODBII port and connect the USB cable to the PC running FDRS. Once FDRS Device Manager pops up, make sure you select Other Device, in the drop-down dialog select VXDIAG - J2534.
After this you should be greeted with this screen, meaning you are ready to go!
The icons at the bottom should be all green with battery voltage shown
Running Network Test (Intial Scan)
1) Turn Ignition On, Engine Off
2) Click Read VIN from vehicle
3) Click Go to initiate Network Scan
Once completed a new tab called Toolbox will appear at the top of your FDRS screen:
On the left hand side you will see all modules detected on your truck. The ones that responded positively will be marked green. On the right hand side notice the SW Updates tab. Head over here to see all available SW updates for your modules.
Module SW Update Procedure
1) Head over to SW Updates tab in the FDRS Toolbox window.
2) If there are updates available, hit the Download button. The tool will download the necessary tools needed for the module update.
3) Once download completes the button turns green with a text "Run".
4) Run the SW Update procedure and follow the on-screen prompts very carefully
IMPORTANT: Make sure you have a solid battery charger/maintainer connected to your truck during the SW update procedure. Last thing you want is the battery die on you while flashing your modules. Do not proceed unless you have solid 12.5V or more showing on your ODBII port.
Be patient, some modules take long time to update. This is especially true for IPMA module which takes almost 3 hours to complete. Therefore, it is very important to have your truck connected to external power supply (battery charger/maintainer)
DISCLAIMER: I have updated many modules with this setup without any issues and zero failures. That does not mean a failure cannot happen. Flashing ECU modules is a dangerous operation. Do this at your own risk! I will take no responsibility for any damage to your vehicle by following the above described procedure
NOTICE FOR FORSCAN USERS: FDRS will knock out your recent FORScan changes from your modules you are updating. It reloads your As-Built (AB) data at the end of the SW update procedure. Make sure you back-up your FORScan changes and load them back after you are done with SW updates. By time your FORScan changes get propagated to your AB data set on FORD servers, so this would not be an issue. This would only affect users performing FORScan changes and running module SW udate within short period of time. I am suspecting, that receiving OTA shortly after FORScan changes would have same effect
Thanks for the detailed write-up. I do have one question. When I launch FDRS, I receive this pop-up regarding an out-of-date VCI update. Do you suggest that you continue through the message or click the link to install the software from Ford's website? @iceman77
Ford F-150 Lightning ECU module programming guide using FDRS Screenshot 2022-01-24 165725
Snakebitten
Coastal Texas
I skipped the suggestion the first attempt, but FRDS failed to work.
The second time I downloaded the VCI software and installed it. FRDS was functional and really stable afterwards.
I don't know if any typical user is going to have a computer already prepared to run FRDS without the VCI software.
iceman77
Pete
2022 Ford F-150 Platinum
Ok, I've done the Forscan stuff and felt comfortable doing it. Now this?? Good grief, why does Ford Make it so difficult for even Ford technicians to figure out?
Are all the updates being described on this post something that would be done OTA or only if forced by a dealer using FDRS?
I hate not being able to see what OTA updates have happened on my truck. The info screen offers very little info. I don't think it's getting updates based on when other owners mentioning they got them. I've seen the "updated successfully" icon only once since I've owned owned it. I also have been getting 'service charging system soon' messages on the dash, especially when it's very cold overnight. But it starts just fine and acts normal. Took it to the dealer and they tested the battery and scanned the truck and said all was fine. Well, if it was, why am I getting that message??
I'm in aviation (as Snakebitten mentioned) and there is a split between the wrench turners and the spark chasers - but it's a split that's narrowing more and more even in aviation.
Ford has designed their modules in a way that they can be recovered from a "bricked" state 99% of time (according to this source). I did not verify this claim entirely, but I managed to "brick" my GSM module, when I accidentally selected VCM II emulation via my VCX Nano device. Programming failed, the truck lit up like a Christmas tree, with all sort of error messages on dash. After changing it back to J2534 pass-through and retrying the module programming, the module got revived and is working as new! Again, this is my experience, and while this experience gave me a boost in confidence, you should still proceed with caution. Sh*t can happen, and even if above statement is true, you never know if you will be that unlucky one hitting that 1% probability
iceman77
Pete
Yes, I used my SYNC4 screen like that USB would not even be there. I did several Master Resets, and battery disconnects, just out of desperation to get this update moving. Not sure if any of it helped, but eventually it kicked in
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Jesse. Is this a complete list of the modules on the Ethernet chain that can be updated OTA? If so, that tells me that none of the other modules in the truck will ever see software updates unless: (1) you do it yourself; or (2) the module malfunctions to the point where a repair is necessary and the dealer can trace the problem to out-of-date software on that module. Thanks.
Snakebitten
Coastal Texas
I don't believe OTA is limited to modules on the ethernet network. The GWM can deliver an update to modules over CAN according to :
Ford F-150 Lightning ECU module programming guide using FDRS Screenshot_20220125-101356_OneDrive
Jesse-Infotainment
I believe it is.. there are only 5 spots.. Trucks that dont have the 8" or 12" cluster that spot is not populated. I added the ethernet to my truck for the cluster. Its not mandatory for functionality but I did anyway.
I cant say at some point ford wont try to push updates to other modules through can bus but I feel it is unlikely. The gateway is the main server so to say. So they could possibly try it but the ethernet was introduce for the speed capability. Can bus is limited. The Bcm for example had an update and it was Dealer(FDRS) only. PCM also. SO I think if they could they already would have
I just wanted to make sure that people understood the OTA is limited right now to those modules. SO that is why it is important to know and have these updates. Early F150s like mine the auto up window didnt work. I had to update both door modules for it to work. THe time it would have taken to drop off and doo all that ... its just a pain. I dont like dealing with them. So the people that have gone the DIY route are making a wise decision. Again at first I wasnt aware of a more budget friendly option. Now there is one it is unquestionably important to have the capability
I may be wrong about the B&O amp but I believe it is ethernet also. Ill have to dig more into it.
JEB
Northern Illinois
Not what I was suggesting. The IPMA can also take updates via the CAN bus. That’s how you do it manually. What I was asking Jesse was for the list of modules that were on the Ethernet. I was not suggesting that Ethernet was the only method for these modules.
