BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
When I first ran the VX Manager I had it to update the VCX Nano firmware. During this update, the VCX Nano license got updated as well! When I checked it was good like for 10 years! Maybe that’s why I have never received a popup message like that
Lic was good till 2030 and it updated to 1.9.0 I think it was. I think the malware was blocking it till I added it to exclusions.
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
I’ve updated all modules successfully. I’m getting a DTC on GWM U2404:92
SSM says to ignore and a Dec 2021 update will correct it. Has anyone else had this code and been able to correct it? I’m worried that my GWM may not be at the most up to date.
https://static.nhtsa.gov/odi/tsbs/2021/MC-10203896-0001.pdf
BlackSheep
Indiana
2021 F150 Powerboost
Are there significant updates for a job 2 truck built in late August? I'm trying to decide if I should spend the dollars to update my truck.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
Well dang, you ARE behind. But that doesn't mean you wouldn't eventually get caught up OTA.
It's your decision. Personally, the co$t is about as much as the dealership charges for a diagnostic fee.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
If you’re concerned, run another network scan in FDRS. If no new software shows up, then you are as up to date as you can be. The ETA for another update in the SSM is not a cause for concern. Ford is not known for sticking to its estimates.
So, if your FDRS network scan looks fine, I’d take the advice in the SSM and not worry about it. DTCs after a module update are not uncommon and this one doesn’t appear to cause any performance issues.
Jesse-Infotainment
2024 F150 Lightning Platinum
Can anyone that did the cluster update in FDRS for an XLT with the 8" cluster confirm if a fix was made for the my view reset?
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Holy shit guys, I went to pull my truck out of the garage and did my ritual of checking if automatic updates were on, AND THEY WERE. I then rushed over to the Sync version and I HAVE DATA. @Jesse-Infotainment @iceman77 can one of you geniuses tell me what version of Sync I'm on?
Ford F-150 Lightning ECU module programming guide using FDRS IMG_1860
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Awesome SpeedRacer! So happy for you! The others updates for APIM in FDRS should be easy going now!
Ruffiano99
Joe
NY
2021 f150
have you been leaving your truck wifi turn on or off? Im still waiting for something to take off with mine. Nothing has worked. Did a master reset yesterday and reset Apim and GWM. No luck on OTA or USB.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
I had left wifi in whatever state it sits after a master reset, but only because I was too lazy to hook it back up after the 12th master reset. I did have the USB drive in, which has been in for I think like 3 weeks now.
BHunted1
Sumner County TN
Started watching some diagnostics while driving. See if I can catch anything happening with the mods or sigs disappearing.
Ford F-150 Lightning ECU module programming guide using FDRS dia
Jesse-Infotainment
I’ll take a look at your vin and see what you are or what update you got. That sync version is old though.. the on in your picture
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
F*ck @Ford Motor Company for making this so infuriating. I went to get gas, turned my truck off and now I’m back to blanks and unable to turn on/off auto updates. I’m so over this BS
