speedracercjr
Cory
Houston
2021 Lariat EB
O&G
I am so happy for you man! Believe or not, every time I visited this thread I was specifically looking for your post that you”ve done it. And you’ve DONE IT!! Good job man!
Thanks man, yall having faith that it would happen kept my hopes up. No freaking clue why it suddenly clicked over, but I'll take it.
I've said it before and I'll say it again, it's absolutely no wonder Ford dealerships don't want, or can't even begin to deal with something as stupid as this.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
This might be a really good time to punch into FDRS and see if you can update to the most recent version of the APIM software. If it takes, you are probably home free.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Yeah I probably should do that to get all up to date. Hindsight being 20/20 I should have bought the 1 month license....GRRRRR
Since I was so focused on getting past the hump, updating APIM again would essentially get me up to Powerup 2.3.whatever right?
Jesse-Infotainment
2024 F150 Lightning Platinum
Glad to see @speedracercjr!
Once you have that done yes you’ll have a date way update and then the apim and tcu and then another gateway update and then you should be fully up to date.
JEB
Northern Illinois
Given what you’ve been through, were I in your shoes I’d gladly pay $50 if it could lock in my updates and set me up for the future. I’d hate to see you miss the window of opportunity like last time.
I think Jesse has answered your questions about updating. The TCU and APIM updates you have pending will get you 2.3.0. There should be a gateway update that will get you to 2.4.1. There should be an earlier gateway update as Jesse mentioned but I’m not sure if you’ll be offered the later one instead. Just keep updating till FDRS stops offering new ones.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
100% agree, here we go again!
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Have you had a chance to look over the doc I created? Put a lot of time in it and would love to have everything together. Thx!
Bob_Mac
Bob
North Carolina
Personally, I'm getting the 30 day one. If there's anyone in or near the Wilmington, NC area maybe we can all get together and split the cost and just use my laptop, battery maintainer, etc....
iceman77
Pete
2022 Ford F-150 Platinum
Since you are out of this 1.7.1 "limbo purgatory" subsequent updates should be easy-breezy and quite enjoyable! Go for it! If you run into any further issues, just hit me up. I'll help wherever I can.
As a side note, avoid Network Scan in FDRS. You'll be just fine without it and can still update your modules
iceman77
Pete
Your doc version of the guide has been published. Thank you for creating it
Bob_Mac
Bob
North Carolina
My pleasure! If anything new needs to be added or changed, please let me know. I went through this entire post and added additional items that were needed. This was originally for my use but wanted to share in hopes that it helps others.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Thank you very much for this thread! @iceman77
I spent quite a while yesterday trying to update my truck with FRDS only to get stuck on the USB update restart to complete the update loop.
Today I was able to update the TCU, GWM (x2), APIM (x2).
Steps I used:
  • Waited for the restart to complete the update prompt displayed on SYNC.
  • Pressed the Close button and shut the truck off.
  • Left the driver door cracked
  • Set a timer on my watch (12min for each of the APIM and TCU updates and 32 min for each GWM).
This process worked perfectly every time after that.
Now that I'm all caught up now SYNC4 (22181) I noticed a few changes.
  • New Audio Screen design.
  • As mentioned above the Cruise Control menu bug exists but I'm curious if others noticed their Intelligent Cruise option is missing?
    Ford F-150 Lightning ECU module programming guide using FDRS 1
    Ford F-150 Lightning ECU module programming guide using FDRS 2
  • It seems this build is ready for BlueCruise.
    Ford F-150 Lightning ECU module programming guide using FDRS 3
    Ford F-150 Lightning ECU module programming guide using FDRS 4
  • The Update Scheduling page has been redesigned and allows you to select multiple days during the week.
    Ford F-150 Lightning ECU module programming guide using FDRS 5
    Ford F-150 Lightning ECU module programming guide using FDRS 6
  • There is now an Update Now button
    Ford F-150 Lightning ECU module programming guide using FDRS 7
  • I noticed a new line at the bottom of the Versions page :)
    Ford F-150 Lightning ECU module programming guide using FDRS 8
I might be wrong but I believe all we need is the IPC and possibly CMR updates for BlueCruise to be functional on Job 1's.
