Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
@Jesse-Infotainment below is my IPC info, F113 (Assembly) is off. Any concern with that?
<NODEID>
720
<F110>DSML3T-1A292-CCE</F110>
<F111>ML3T-14F094-CAB</F111>
<F113>ML3 T-10849-CCM</F113>
<F120>MU5T-10F906-FDA</F120>
<F17F>1PB11BFK</F17F>
<F188>MU5T-10F906-FCA</F188>
<F18C>MCCP036872</F18C>
</NODEID>
Jesse-Infotainment
2024 F150 Lightning Platinum
<NODEID>
720
</NODEID>
Those look like 5.0 cluster files? Is that what you have
Jesse-Infotainment
Ok . So yes. What happened to you is what I believe is happening to everyone. It loaded the as build portion and failed everything else. To put into per this update should have taken hours.
Here is my current files on a V8 not updated !
Now his is ideal for comp sake.
Make of this what you want but three files should have been updated .!
Ford F-150 Lightning ECU module programming guide using FDRS 8BFB1C27-2438-449E-AA77-7E35286192A4
Jesse-Infotainment
If you can look in your usb and see what files are on it those are the files that should be in your cluster
Bob_Mac
Bob
North Carolina
I only have 1 file on the USB; MU5T-10F906-FDA.VBF which is what F120 should be and is based on what I posted above.
Jesse-Infotainment
Should have been three
Jesse-Infotainment
Yeah. That was what everyone was getting.. I’ll try to do a v8 update tomorrow and see what I get.
Bob_Mac
Bob
North Carolina
Any consolation... my instrument panel is fine... no issues. Keep me posted and thx!
JScaro
Georgia
2021 Ford F150 Lariat
Beer Drinker
While in the toolbox click the All tab then click on TDM on the left side you should see a new tab show with TRM as it's label now click on TRM - Programmable Module Installation (PMI) then Download and run. Go through the prompts as if you already installed a new module and report back if that cleared your DTC
The GSM will not go away... disregard it as it appears to be a bug
OK @Bob_Mac , Downloaded and Ran the PMI, still shows DTC
Should I download and run the others?
Ford F-150 Lightning ECU module programming guide using FDRS 1645985084877
Jesse-Infotainment
Trm will have a dtc there is even a tsb about it.
JScaro
Georgia
Beer Drinker
@Bob_Mac
Next question, got the APIM usb to kick off but now it shows I still have a software update in FDRS. Might be because I’m so far behind, haven’t had an OTA since November. Here is some screen shots. I only have today left on my license so any sudjestuons or just wait a few days and see if things progress like they should.
Ford F-150 Lightning ECU module programming guide using FDRS 1645986049036
Ford F-150 Lightning ECU module programming guide using FDRS 1645986093403
