Jesse-Infotainment
Has to do with the network scna.. Iceman has a solution
After all this time, you’re holding that against me? Comeon man, we’re all frustrated. Its not personal. Sheesh.Seriously? This was you, right? https://www.f150gen14.com/forum/threads/power-up-2-3-0-ota-rolling-out.7724/post-155699
Is there any info I can send ya from my recent updates?The OTAs are hard to say what level. OTA coincides with a update that you have done manually.
The updates for ota have been targeted up until 2.3.0 and it did the APIM and TCU
1.4.0 was TCU - Securalert
1.6 was gateway
1.7.1 was APIM 21146
2.0 was gateway
2.1.1 was gateway
2.3.0 was APIM/TCU they had to be done at the same time
2.4.1 was Gateway a fix for the Zone light Drain
2.4.3 was Step One IPC update
2.4.4 was step two IPC update
2.4.5 was an APIM update to 20282
2.5.1 was 4 Modules IPMA, CCM, CMR, PSCM
So to ask what version OTA you are at is not relevant when you have been manually updating.
Every update up until 2.5.1 has been released on FDRS. The other thing is if you have updated modules they have no association with an ota and otherwise would have not been updated.
This is interesting, my truck stalled on 1.4.0 but I'm pretty sure I got 1.6. Haven't been able to get any OTA updates after that. Never had the issues with not being able to turn on Auto updates or see the sync version, just always failed the OTA's after they rolled through their install windows, and now it has stopped trying anything, the last window I had was from Feb.The OTAs are hard to say what level. OTA coincides with a update that you have done manually.
1.6 was gateway
2.0 was gateway
2.1.1 was gateway
You likely got a broken 1.7.1 which exploded for a lot of people. I finally got mine fixed after creating an USB from FDRS and leaving it plugged in for a month. I haven't heard any official word from Ford yet either on a supposed fix they were supposed to have for it...This is interesting, my truck stalled on 1.4.0 but I'm pretty sure I got 1.6. Haven't been able to get any OTA updates after that. Never had the issues with not being able to turn on Auto updates or see the sync version, just always failed the OTA's after they rolled through their install windows, and now it has stopped trying anything, the last window I had was from Feb.
@JEBThe OTAs are hard to say what level. OTA coincides with a update that you have done manually.
1.6 was gateway
2.0 was gateway
2.1.1 was gateway
Here is @iceman77 ’s fix for the missing SecuriAlert function. https://www.f150gen14.com/forum/threads/ecu-module-programming-guide-using-fdrs.8249/post-167846Has to do with the network scna.. Iceman has a solution
That was you?After all this time, you’re holding that against me? Comeon man, we’re all frustrated. Its not personal. Sheesh.
And you were needling me dude.
You should already have mine...I'm looking for VINs guys. I'm trying to collect some data and test something I recently created so the more VINs you PM the better.
I'm trying to build out some module data info, plus this will also help with letting you guys know when you may have updates available.
PM’d youI'm looking for VINs guys. I'm trying to collect some data and test something I recently created so the more VINs you PM the better.
Yes. I’ve seen it, at least the part beginning “FFF1.” So has @Snakebitten and @TJSparky . They posted screenshots around post 1018. It seems to be a bug in FDRS when displaying the APIM strategy. It will show a normal strategy after a network scan and then a couple of hours later it’ll change to this nonsense. And then it will change back.Ever see this number for the Sync?
DID F0E9 - FFF1-14D358-FF
