Ajzride
Alan
Houston
Eng
My TPMS went away after a few miles of driving. I thought I was going to be Firestone bound the next morning but it cleared up before I had a chance to go.
iceman77
Pete
2022 Ford F-150 Platinum
NOTICE: I have updated the guide to reflect the changes to the preferred VCI device being the Mongoose-Plus as well as well as posted warning not to perform Network Scan if you decide to stick with the VCX Nano device
I apologize for the delay, I have promised to update the guide a week ago, but after 2 years of avoiding the COVID plague, this time it got me and hit me pretty hard :rolleyes:
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Hope your feeling better. I’ve been there 3 times and I’ve been vaccinated.
I never get sick but somehow Covid busts right through my defense.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Apologize? You’re doing uncompensated work while suffering from a killer (literally) virus. That’s silly.
Not to add to the burden, but it’s worth mentioning that when you install the drivers for the Mongoose, the installer will also install something called the J2534 Toolbox. I strongly recommend running the first three diagnostics under the Support tab (Install, Vehicle & Device) before using the Mongoose the first time. @Bob_Mac initially got corruptions until I had him run the diagnostics. One of them found something, corrected it and it cleared up his corruptions.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Do you have a backup of the module from FORScan?
you can restore that to the module and your tpms should restore its config.
this happened to me :)
Just a follow up for future readers, if you get the weird disco lights after a BCM update restoring your as-built as @tonesto7 suggested fixed it for me. Thanks!!
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
jmm3807
Phoenix AZ
www.seasavvyaquarium.com
2021 F-150 Platinum 4x4
Business Owner
Got the mongoose pro in. Just double checking here that running network scan will not corrupt like it does with the nano?
Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
@speedracercjr , the asbuilt you restored, is it the asbuilt prior to you performing the module software upgrade? I download from motorcraft website my asbuilt before and after to compare the changes that were done with updated module software. Isn't restoring to the prior asbuilt defeating the purpose of the software update, or am I misunderstanding this process?
JEB
Northern Illinois
No, not if used properly. Make sure you run the first three diagnostics under the Support tab of the J2534 Toolbox. This is important. The Mongoose must be plugged into the truck with the ignition on, engine off when running the diagnostics. If all checks out, you can then immediately proceed to FDRS.
Bob_Mac
Bob
North Carolina
I'm actually adding these steps now to the doc that'll be ready soon...
JEB
Northern Illinois
Think of it this way: The software is essentially firmware—the basic programming of the module. The as-built data are the variable configurations/settings applied to that module so that it operates properly with your specific truck. If you look in other parts of FDRS, you will see a tool called “[module] configuration” which is what FDRS calls the as-built data loader. You can change the settings/configuration without overwriting the firmware.
Ebrou
Mobile, AL
Thanks @JEB for the reply, after I updated my IPC, I did not run the configuration tool, should I have or only if I have enco7ntered issues after the update? I have not noticed any problems and it has been about 2 weeks since I updated it via the CANBUS. Thanks again!
