BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Do any of the BlueCruise updates (equivalent to 2.5.x PowerUp) require Key On/Engine On? I know when doing updates a couple weeks ago to get my truck to 2.4.x equivalent level, the IPC update had the engine on, the rest were engine off. Just trying to plan my day tomorrow as I plan on updating things again.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Jaug
Jason
Fargo
2021 F150 Platinum
From what I remember
GWM engine on (I think this was power up 2.5.2)
APIM engine on (I think this was power up 2.5.3)
Hope this helps
abd79
Wayne
2021 F-150
Anyone have access to PTS? For some reason my VIN is showing the following and I suspect it may have something to do with OTA update not working but also not being able to send data to the mothership?
Ford F-150 Lightning ECU module programming guide using FDRS Screenshot 2022-03-18 093143
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
I have looked high and low to break the restart loop on the TCU. I have seen suggestions but nothing that works. Please point me in to the right direction. Throw a dog a bone I want BC too :(
What fixed the stupid restart loop for me was getting a new battery. Yesterday @tonesto7 was stuck in a loop and had success disconnecting his battery and charging it for 20 minutes, then reconnecting & the update finished. I don't know if that is the true cause of the restart loop, but those are two examples related to voltage issues.
imnuts
Dirty Jerz
Facilities Engineer
Hope this helps
Thank you, definitely helpful. Going to park somewhere different knowing the engine will have to run while updating.
Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
My 3 day subscription to PTS has expired, but make sure you have connected on in your trucks sync system settings. Be sure your using internet explorer, and send your email approval to retrieve your pin code to allow access to your truck from within your PTS active subscription.
abd79
Wayne
2021 F-150
How do I send my email approval?
Ebrou
Mobile, AL
Once you login to PTS, just under VIN and to the left there is an option to give access to your connected vehicle. you will put your email address in and select send. the email you receive will have a pin number which you will use to validate in PTS to allow you access. The pin box will appear in the same location you just put your email in. You will only need to do this once during your session. It usually lasts me through the 3 day license period. once you enter the pin and send again it will load your vehicle information. You can still manually load your vin, and view TSBs, SSM repair manuals, wiring diagrams and sync information. When you do the authorization process with the email and PIN you will be able to see DTC's and additional owner information. I normally due the FDR and PTS subscription together just incase I need TSB and manual information.
Sorry this is the best I can give you sense it has been a while sense using PTS.
abd79
Wayne
2021 F-150
Ok, I don’t have that option so must be a PTS issue.
