Foxtrot150
Houston, TX
2021 302A PB SCrew 6.5
Not while charging. Turn off everything and walk away. Just let the truck fully shut down and leave the charger to do its thing. Check your charger periodically. Once you are fully charged, yes, you’ll do most of the work in accessory mode with the accessories I mentioned off.
Looks like I may have a bad battery. The charger went into abort mode. After plugging the charger back in to check status, it says 11.6v at 10% charge (obviously estimated). FDRS wouldn't go higher than 12.1v.
Ford F-150 Lightning ECU module programming guide using FDRS IMG_20220318_165236415
Ford F-150 Lightning ECU module programming guide using FDRS IMG_20220318_165242350
Jesse-Infotainment
2024 F150 Lightning Platinum
@Bob_Mac @Jesse-Infotainment @iceman77
Is it possible I some how screwed up installing the GWM update. I went into sessions from yesterday and all updates i did including Apim that was released after GWM are there but no GWM. Im not being offered anything in Bluecruise .It said there was a failure but it cleared from FDRS and theres no history of the install. Im now realizing if you dont do a network scan of the truck the session history does not save
sEND ME YOUR VIN ..
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
That’s not good. Have you tried different positions with the negative alligator clamp to see if you could find a better ground? I haven’t had good luck with some of the alternative grounding points I’ve read in this thread and am now back to using the hold-down rod. I just rotate the alligator a little around the rod just below the nut until I get a small spark and it seems to work fine. Or at least well enough.
If you can, see if you can buy or borrow a battery tester to load test the battery. Since you have a Powerboost, you will have to disconnect the auxiliary battery if you need to remove the starter for further testing.
The good news is you found this out BEFORE you started to program. You’ll be glad you did.
abd79
Wayne
2021 F-150
For those of us in Canada that have done all the updates but not received their BC activation through the FordPass app or online all I can say is be patient. It took 48 hours for mine to kick off and I received this today!
Ford F-150 Lightning ECU module programming guide using FDRS 30559D76-3440-451A-8432-D77E832224F5
Foxtrot150
Houston, TX
Definitely got a little spark, but maybe I'll try the rod again.
Is there documentation on removing the battery on a PowerBoost? Was thinking about taking it out and over to an auto parts store to have it tested.
JEB
Northern Illinois
There is in the shop manual, but you don’t really need it. Raise the rear passenger-side seat cushion and you’ll see a plastic cover with four (?) hold down tabs. Remove the cover and you’ll see the battery. Remove the negative battery cable and then the positive. That will isolate the aux.
Foxtrot150
Houston, TX
Thanks. Then I can pull the battery from under the hood like other vehicles?
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
Honestly, I have always done every update that ever populates FDRS as available.
Of course there are a few that even after applying them they are not removed, but it's easy to just work around those.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
I did a APIM update couple of weeks ago did you have another pop up after this latest round? I seen a new GWM popup and was wondering if I need to look for another APIM also.
you’ll have another and I’d follow what Snake did. Might as well update everything
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
So after talking with the expert @Jesse-Infotainment I did a PMI on my GWM module. I selected that I installed a new module. Once complete Bluecruise is now available. Not sure what happened during initial GWM update but its all good it works GREAT!!
