Foxtrot150
- Jan 18, 2021
- Houston, TX
- 2021 302A PB SCrew 6.5
Looks like I may have a bad battery. The charger went into abort mode. After plugging the charger back in to check status, it says 11.6v at 10% charge (obviously estimated). FDRS wouldn't go higher than 12.1v.Not while charging. Turn off everything and walk away. Just let the truck fully shut down and leave the charger to do its thing. Check your charger periodically. Once you are fully charged, yes, you’ll do most of the work in accessory mode with the accessories I mentioned off.
