abd79
Should have more clear. Not connecting directly to the negative battery terminal but rather connecting after the battery monitoring electronics on the negative body side of the battery. That point your connected to is a 10 gauge wire directly to that point on the battery. It has a large flat connector which is easier to connect to.It's detailed somewhere in the thread. If you hook directly to the battery for both terminals, it can interfere with the module responsible for maintaining battery voltage.
