Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
i answered my own stupid question, I can see the data in FDRS, it is corrupted there as well.
Am I destined for a dealer trip? How the hell do I fix a corrupted module?
That's not a corrupted module, you have a DTC. Can you provide us the DTC it's showing?
Jesse-Infotainment
2024 F150 Lightning Platinum
I just want to add in regards to the IPC. The issue with the configuration comes from it going from 11 to 14 lines. So when it tried to configure it doesn’t have the extra lines ready for some reason on fords end. Causing the config failure. Then the dtc that is about initia config not done is due to the new as built never being written.
The PMI fixes it and takes a day sometimes because ford finally updates the database to reflect 14 lines of as built.
This is why you are having issues
second in regards to the ipma. Do not try to write your old date to the new ipma software! You will create big problems! Don’t do it.
Ajzride
Alan
Houston
Eng
The DTC is U2100, no initial config. The reason I think it is corrupted is because the Part number is wrong.
If the USB update had gone through and not the CAN update I would have
F120: ML3T-14C026-CRC
F188: ML3T-14C026-CPC
If the Can update had gone through and the USB then I would have
F120: MU5T-10F906-FDA
F188: MU5T-10F906-FCA
But what I have is
F120: MU5T-10F906-FDA (USB and CAN Updates Went Through)
F188: ML3T-14C026-CPB (This looks like the USB went through but corrupted the code from CPC to CPB, and then CAN never went through).
Ajzride
Alan
Houston
Eng
I see what you are saying, but it's been almost 96 hours since my IPC CAN failed and I still can't PMI it or clear the DTC.
Bob_Mac
Bob
North Carolina
But what I have is
F188: Ml3T-14C026-CPB (This looks like the USB went through but corrupted the code from CPC to CPB, and then CAN never went through).
And as I said to @Skier167 you as well as he will have to fail the update and go the CANBus route
Also, have you made any IPC FORScan changes and if so, which ones?
Skier167
Nate
Ohio
2016 f150
Are you referencing changing the
Have you made any IPC FORScan changes and if so, which ones?
@Bob_Mac yes I made changes for adaptive headlights to the two below
720-01-01. 22FOA 3064 F4EA
720-10-01. 0B18 0061 00BC
Jesse-Infotainment
What I am saying is DO NOT load all from an old back up.. You can make changes but dont load all
