MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
Well crap...my IPMA failed it's update some point after 70% in the big block 1 of 2 portion of the update. No clue why. Voltage is at 13. Trying again (using a Mongoose)....
Failed again...Now I'm getting this:
How did you get past this?
Sbdavis1
Stephen
Fayetteville
2010 F150 Lariat ordered 2021 F150 Lariat
Financial Planner, Lawyer
For those Who were fortunate to get past 1.7.1 via OTA, should we revert our Forscan changes before anything else gets updated via OTA? I have anti-glare headlights, double honk disabled and cameras in motion via ForScan but don’t want any of that to mess up the updates supposedly coming via OTA.
Ajzride
Alan
Houston
Eng
I can say that my double-honk and cameras in motion don't appear to have messed anything up. But I think the Anti-glare is in the IPC, which is what has caused the headaches, so I would definitely undo those.
It appears that if you corrupted your IPC (as I have done) you will have to ship your IPC out for repair to recover. So roll back any IPC changes in Forscan to avoid that mess.
Ajzride
Alan
Houston
Eng
I believe myself and Platinum Peasant had that error and we changed laptops and it cleared up. uninstalling FDRS and deleting all data and re-installing might work as well. Be sure to release your license before you uninstall.
MikeYQM
Moncton NB Canada
It’s not me, it’s a ford tech who got stuck
MikeYQM
Moncton NB Canada
Can anyone run my vin for updates, please?
1FTFW1ED2MFB10996
heffer86
Iowa
2021 F150 Lariat 501A
I am up-to-date with my modules updates via FDRS. I got a Motorcraft PTS subscription (OASIS) to see if I am even being sent OTA updates so hopefully I don't need to do this forever. When I get into my vehicle data I get this message below. In the past it would populate all my data here. I have tried difference browsers and waited overnight. Still same result. Anyone else who has done updates tried tried the PTS site? If someone else has a PTS subscription and willing to try on their end let me know.
Ford F-150 Lightning ECU module programming guide using FDRS 1648130707119
christophers
Christopher
Austin, TX
2021 F150 Platinum Hybrid
My anti-dazzle lights were done in ForScan several weeks ago, and I did pre-1.7.1 all the way to BC with no issues.
EDIT: just because i didnt have issues doesn't mean you should follow my example :) take the time to do things the right, safe way and you will have minimal to no issues.
ksimon123451
Kelly
21 F150 Lariat
Systems Administrator
I went through the process of trying to restore APIM with the new process Ford just released to kicking off the usb update from 1.7. I started it and went through till it asked me to connect the usb to the truck I said yes, I tried just using a USB C from my laptop to the USB C port on the truck as I dont have the adapter. It said that it cant find a connection so I aborted it. Then when I checked my version on the screen under settings it was no longer blank so I inserted the USB drive that has the APIM update and it started after 10 minutes. Don't know if it was a fluke but it worked for me.
Ruffiano99
Joe
NY
2021 f150
Think it will be safe to attempt this new TSB with a nano?
nothing has worked for me yet. I made changes in forscan months ago… double honk, pedestrian sounder, global windows, i had messed around with cameras at speed but it never worked, i cant remember if i set that back to original values.
RellIk&5
Wayne
Las Vegas, NV
2021 F150 XLT Black Widow
It's been over a week for me since I applied my last batch of available updates. My rev is still 244. Can someone please check this vin to let me know if there is anything new aside from the GSM?
1FTFW1E86MKD74376
Thanks!
christophers
Christopher
Austin, TX
Honestly, I wouldn't attempt anything with a Nano at this point.
Ajzride
Alan
Houston
Eng
1FTFW1E86MKD74376
Thanks!
Still just the GSM for you.
antho
Anthony
Houston, Texas
2021 801A Raptor
If I made any changes with forscan, will this possibly cause my GWM to not update? I can't seem to get it to clear.
@20ecoboost21
I have a GWM that won’t clear either. I load the 14files via usb successfully and FDRS finishes and seems to be good to go but the update won’t clear in FDRS.
