Jesse-Infotainment
2024 F150 Lightning Platinum
I finally had a chance to spend the day yesterday with a Mongoose and FDRS license. I have a 2021 job 1 and was hoping to finally get BlueCruise.
I had about 15 updates to install. There was no APIM update listed. All of the updates installed successfully with the exception of a GSM update that won't seem to go away and my Instrument Cluster Module. It gave me the attached error and then the update disappeared from my list. My sync version is still revision 244.
I saw a previous poster had a very similar issue a couple weeks ago and reported it solved, but I'm not sure what the resolution was. Any ideas on how to keep moving my updates forward? Thank you!!
VIN: 1FTFW1ED0MFA94376
You are where several people were. The FDA is loaded. That’s actually a good thing because it’s the large file. The 188 should be fca and takes about 4-5 mins. You can try a PMI and see if it will now load the fca. If not we would have to side load that file. Yoo poop u won’t get any further until the cluster has the 188 is at fca
jordandev
Jordan
2021 F150 XLT 302A (on order...)
Are there any modules that are not safe to PMI at all?
Jesse-Infotainment
You can PMI any module. You just want to be sure of the circumstances when you do.
Mike G
N. AL, USA
Jesse, how does one go about side-loading? Is there a written procedure for this? Is it similar to the process used to UF the APIM that's stuck at 1.7.1?
LariatGuy1
F150 Lariat
Thank you for looking at it! I just tried to do a PMI and received the attached error.
Ford F-150 Lightning ECU module programming guide using FDRS PMI_Error
islandboy47
Adam
2021 Powerboost
I ended up getting a new battery charger and have been doing updates all day with no problems at all so far! But I just watched Slappy Mcgee's video and that was the first time I heard anything about taking trim off and unplugging something/using an adapter. I'm still not clear on what I need to buy to be able to do that - I thought all I needed was the 3.0 USB stick, as it doesn't say anything about adapters in the guide. Can someone shed some light on this for me please?
Ajzride
Alan
Houston
Eng
That procedure is only necessary if your APIM is stuck in purgatory and won’t execute USB updates. If your updates via USB are working you can skip that procedure.
Jesse-Infotainment
It’s not something just anyone can do. No it’s different.
jeffm4688
NY
2021 Platinum, 2012 M3
I am looking to get this done this week but of course can't find a mongoose-plus in stock anywhere.
Can someone answer if the CCB needs to be updated in order for me to get bluecruise working(2021 job 1 truck)? If so and I order the VCX nano I assume I am DOA?
I'm about to take a 1300 mile roadtrip (each way) and would kind of like bluecruise...
JJ_Tex
Prosper, TX
2021 F150 Platinum Powerboost
I've read the Nano has issues with the Cruise Control Module (CCM) and just based on the name I would assume that is needed for BlueCrusie.
Amazon has the Mongoose in stock and looks like you can get it by the weekend:
https://www.amazon.com/Mongoose-Plus-J2534-Vehicle-Interface-Cable/dp/B097NHQ7ZW/
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
If you updated via the nano not only would you not have Blue Cruise, you'd lose cruise control completely. That would make your 1300 mile trip REALLY suck.
Jesse-Infotainment
Ok. Well get with me and I can work with you to side load it.
islandboy47
Adam
2021 Powerboost
I tried updating the IPMA last night, fully expecting it to take 3+ hours, but it actually ran for about 9 hours - not kidding. Then at the end it said there was a error/it was unsuccessful. Pretty annoying. Did anyone else run into this error? Should I have updated something else prior to the IPMA? Prior to this I've updated the PCM, ABS, SOBDMC, BECM, CCM, PSCM and the CMR. Still plenty left to do lol.
Ford F-150 Lightning ECU module programming guide using FDRS FDRS
JScaro
Georgia
2021 Ford F150 Lariat
Beer Drinker
Be sure to follow these directions, many modules requires others the be performed before they will take.
