"Steve"
"Steve"
Sandy Eggo
2021 F150
might just be that point in the process where people said to let it sleep overnight...?
"Steve"
"Steve"
Sandy Eggo
2021 F150
no change. hmmm. still getting cannot connect to VCM. i cant move on to the rest of these until this is sorted, eh?
and i shouldnt need to do the multi module repair again, right? that was just to repair APIM for the frozen updates?
Ford F-150 Lightning ECU module programming guide using FDRS updates
ogor6037
Marcin
Crystal lake IL
'21 F150 xlt 302a
On more question while im doing usb update on APIM or any other one that takes long can i shut the truck off but leave ignition on plugged to power supply? Thanks
Nevermind it didn't take that long until restart for a minute i thought it will take forever now im just going to leave for at least 10 min per instructions
"Steve"
"Steve"
Sandy Eggo
2021 F150
^ my powerboost makes a few audible clicks when shutting down. ive heard one that goes off around the 10 minute mark. i wait for 2 or 3 clunks, 10min, and she was good.
SharkAttack
2021 F150
Got started on some updates today but running into an issue. GWM update downloads, the truck accepts the update and says its complete. After restarting following the outlined process, everything seems fine but running another network scan shows another GWM update. I wasn't really paying attention to the numbers, I just assumed it needed many updates. After the 5th time I got suspicious and it looks like its downloading and trying the same update over and over. Anyone ran into this before?
Ajzride
Alan
Houston
Eng
GWM or GSM? The GSM is known to not clear out, it's mislabeled.
"Steve"
"Steve"
Sandy Eggo
2021 F150
same error im getting. trying to do a 2nd gwm update it says i need. going to try leaving overnight i guess if i shouldnt update the others.
ogor6037
Marcin
Crystal lake IL
'21 F150 xlt 302a
Yup getting GWM update issue also...so i went through the process waited over 10 min came back turned ignition on it would not show on sync as update successful anyway long story short got the same massage could not communicate with VCM now GWM is still in orange did self test and it cleared reran network test its back in orange ran self test again now i have DTC
Ford F-150 Lightning ECU module programming guide using FDRS IMG20220416164351
Ford F-150 Lightning ECU module programming guide using FDRS IMG20220416164345
Ford F-150 Lightning ECU module programming guide using FDRS IMG20220416164340
Ford F-150 Lightning ECU module programming guide using FDRS IMG20220416165056
turbopilot
Flagstaff, AZ
F150 Powerboost
Getting ready to take my turn at TSB 22-2117 to unstick the APIM/TCU. Have the hardware including the Mongoose-Plus. About to load the software. All the online posts simply say download the FDRS software. When going to that page there all multiple steps listed with many software downloads. Just want to confirm that FDRS 31.6.7 is all that is needed.
Ford F-150 Lightning ECU module programming guide using FDRS FDRS
Dishrag
2021 F150 limited
Quick question. Are the licenses the same for FDRS and FJDS? I bought the 30 day and assumed it was the same as there wasn't an option to get one specific for FDRS. When I try to put in the activation code in the FDRS software it fails and can't activate.
Ford F-150 Lightning ECU module programming guide using FDRS FJDS
FordConvert
Craig
Utah
2021 F-150 Lariat PB 502A
Builder
That is all you need.
FordConvert
Craig
Utah
Builder
think i got some dtc too. should i resolve these first?
Those will resolve as you update. If you’re still getting the “data” error on the GWM then it needs to sleep overnight. That did it for me.
