FlasherZ
- Mar 10, 2022
- St. Louis Metro
- F-150 Lightning, Tesla Model X, F250 SD diesel 6.0
That UF-B cable will be fine for a hardwired EVSE with 40A charging or less.so what would be needed for an EVSE charger?
For an EVSE with 48A charging load, #6 THWN in buried conduit is the best option.
For larger EVSE's (e.g., the Ford Charge Station Pro), it depends upon the amount of charging current you want it to offer. At that point, it's pretty much wire-in-conduit and you'll size the wires based on charging loads. For the most common beyond 48A charging (72A charging or 80A charging), you'll want #3 wire in conduit.
