what is this button for?!
tx_lightning
TX
2013 F150, 2022 Lightning XLT XR
What is the N Clock button for?? I don't see anything changes on the dash when i press it.
Ford F-150 Lightning what is this button for?! PXL_20220701_173237086
Theo1000
Theo
Shawnee, KS
Audi Etron,Chevy Volt,BMW I3,Mach-E,F150 Lightning
Think that is the car wash neutral button. permanent magnet motors are not intended to freewheel unless the car deactivates stuff. esp. if no driver and vehicle is not on.
Firestop
Firestop
Temporary Neutral activation
From the Owners Manual……..
Ford F-150 Lightning what is this button for?! FC13C10B-7922-4579-AB2D-14823615EA97
Ford F-150 Lightning what is this button for?! 1FF7C35A-B8C6-4722-A4F4-6FE0C100D831
Put it in Neutral, then press the button.
Hamtech
Madison
KIA Sorento, Tesla X
Lawyer
The manual does a good job of explaining its use. But to further explain: your car will go back into park when the door is opened, even if you have the shifter in N. The button allows you to put the car in N and exit the vehicle.
I believe this function exists in all EV cars. In my Tesla it is called car wash mode.
Also, I really recommend you read the manual. There are lots of features that have received little attention on this forum or other videos.
I have had my Tesla for three years and I still refer to the manual for features I seldom use.
Skidrowe
Gideon
2022 F-150 Lightning ER, 2014 Honda Pilot
Make sure your sunroof is open before pressing it.
GarageMahal
JT
Data Wrangler
On a related thought, what does putting the Lightning in "Park" actually do? I am assuming something physically engages somewhere in the drive line to prevent the wheels from rotating but does anyone know exactly what happens?
Thanks
jta
tx_lightning
tx_lightning
TX
thanks! I did search the manual, but I had no clue what I was looking for!
so this only needed when exiting the car and you want it to stay in neutral up to 30minutes? I can’t ever see needing this in my life
Thanks
jta
Most likely similar to a automatic transmission, a solenoid actuated pawl prevents the reduction gear from turning
Firestop
Firestop
Agree…….
sotek2345
Engineering Manager
If you break down and need to get pulled on to a flat bed, you will need this.
Hamtech
Madison
Lawyer
At a car wash is when you will use it, unless you go to one of those touchless washes that moves around your vehicle.
This feature is unique to EVs.
