- First Name
- Adam
- Feb 15, 2022
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Occupation
- Drug Dealer of the LED World
That's a good deal then IF it's in fact the PRO (aluminum) one.I just did a build and noted an anomaly - you can order the Retrax off list on the Lightning. It is still listed on all other F-150 and Super Duty models, but for some reason has dropped off the Platinum build page - but there is a way to order it there. You can add the Retrax cover by selecting one of the Yakima rack accessories that requires the XR rails - it then adds the correct bed cover into the build. So it is a Ford website problem - I promise you that you CAN order the Retrax XR as an OEM item for $1,695 - and it still works correctly (listed separately) when building any Ford pickup on their website except the Lighting - and you can force it on the Lightning by choosing a rack that needs that top. This must be a recent website change/error because it was fine when I built my truck. And, as you can see in my window sticker above, it is on my Lightning as OEM. Below are two screenshots I just took - one showing how I added the Retrax to a Lightning by adding a Yakima rack, and one showing it as an option for a standard F-150.
