Weird Frunk Behavior
swesson
Scott
CO
Today, I opened the frunk and left it open while it did some work. It was probably open for 30 minutes. When I went back, I couldn’t get it to close with the button underneath or with the button on the fob or inside the truck. So I turned the car on and tried again. Nope. Turned the car off and locked it for awhile. Nope.
So then I decided that maybe the motor or the sensor was confused about what state (open or shut) the frunk was in, so I manually closed it. That did the trick and it has worked ever since.
Just posting this those that might run into this in the future.
jazzmanmonty
Lincoln Corsair
self employeed
Im having a problem with mine where if i open with the key fob, it will only close with key fob. Inside button won't work. But it i open with latch, i can close with button inside or keyfob. Anyone else experience this?
Mike G
N. AL, USA
I haven't experienced that specifically. I have opened it with the fob and closed it with the fob. And opened it with the fob and then after loading closed it by hitting the frunk button. And I've opened it with the inside hard button near the light switch and closed it with the frunk button.
But like the OP...that has happened to me three times now. I had the frunk open to run the powersupply while programming in FDRS on three separate occasions. And at the end of my programming events after putting the powersupply away and putting the right jumper point cover back on I ended up each time closing the frunk manually because pressing the frunk button resulted in the three beeps and that's it. Once it was closed, I could press the button and it would open, and then close again after another button press. So I don't know if it has something to do with staying open for like a half-hour or what.
But yeah, mine's done that too. And as Ford will likely tell you....it's a "characteristic" of the Lightning, not a "problem" :sneaky:
gorwell
Sacramento
Ioniq 5 / XLT Standard
I seem to run into this. Sometimes it just won't close with the button and have to use the key.
Marcoux
Stéphane
Ontario, Canada
F-150 lightning XLT
Yup, everytime. I was thinking about bringing this up with the dealership, but I'm wondering if it's something that can be fixed OTA
saturnschildren
Glen
Peterborough, Ontario
www.glenhunter.ca
2022 Lightning Lariat XR, 1963 Lotus Elite, 1953 Unimog 401
I had the exactly the same problem as OP last weekend. Packing up to leave the cottage and left the frunk open for an hour or so, went to leave and the frunk wouldn't close - it played the 4 beeps error code no matter what button was pushed to close it (frunk, fob, dash). Ended up using the manual close method detailed above and it has worked fine ever since. I thought that maybe something had shifted in the packing and hit the emergency release button since that can apparently cause problems getting the frunk to close, but maybe it's a bigger issue. @Ford Motor Company might be something to look into.
jazzmanmonty
Lincoln Corsair
self employeed
New problem today. While closing frunk, it wouldn't latch. Had to take it up and down a couple times before it finally latched.
Firestop
Firestop
Thank you!
I experienced the same behavior on the first day I owned my truck. I left my Frunk open in my garage overnight, and when I came out the next morning, it wouldn’t close. Apparently, the truck “lost” the position of the Frunk lid when it “fell asleep”. I gently manually closed it…it latched…no problems since, though I don’t leave it open overnight anymore…….?
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there, Chris. Will you send us a message with your VIN and dealership info? I can look into things on my end.
The Unc
Brett
Coos Bay, OR
2023 F150 Lightning
Tech
Is there any new info on this issue?
I have been experiencing this problem for a while... Frunk won't close after being open for a while. Only way to close it is ti do it manually.
Seems like a big glitch!
Ford Motor Company
F-150 Lightning
Hi there! Go ahead and send us a private message with your VIN and dealer info, and I’ll look into this frunk concern for you. Thanks!
