Blue Cruise maps out of date
Jaufry
Ethan
Maine
2007 Tacoma
Manager
Is anyone else having an issue with OTA updates for their bluecruise map? I took delivery of my truck right after the map expired on Sept. 10th, so I haven't been able to use hands-free driving yet. It seems like a known problem, at least amongst Mach-E users, but my dealership doesn't seem to be able to help. Reading a few messages it seemed like I needed to take it in for a GWM update, but they at first couldn't find anything, then when I pointed out the "fix" in a Mach-E thread they were able to see that there was indeed a problem, but it apparently doesn't apply to my truck because it falls outside the production window that Ford has deemed prone to the problem. Now I'm being told that they don't know what the issue is, even though it's the exact same issue others have reported!
At least they're "keeping my case open" for whatever that's worth.
ccpro
Quebec, Canada
F-150 Lightning 2022 Lariat ER
Construction
At least their "keeping my case open" for whatever that's worth.
Same thing here ! Dealer doesn't do anything :(
lancersrock
Kody
USA - IA
2021 Honda Pilot, 2011 Mustang GT, 2013 fusion se
Field Engineer
Do you have a link to a thread from the Mach e forums?
Jaufry
Ethan
Maine
2007 Tacoma
Manager
PV2EV
Did the service department offer another reason for the failure of hands free, or offer to escalate it to Ford (beyond keeping your case open)?
Jaufry
Ethan
Maine
2007 Tacoma
Manager
They said they were on the phone with Ford engineers, who would also open the case for my truck specifically, but they didn't have a solution. It almost felt like a "We've never seen a model quite like yours before" answer
I'm not familiar with this issue. Can you elaborate?
BlueCruise uses maps that tell the system what roads have been approved. These maps have to be updated regularly. Initially, this was believed to be every 6 months. Then in an update (for the Mach-E), it was indicated that they would be more often.
If the maps expire, you won't be able to do handsfree driving until your maps are updated. Ford did an "emergency" update on the Mach-Es just recently, and some owners didn't get it, and their maps didn't work after that date.
You can see the date of the maps you have in the vehicle where it shows you the version of Sync you have. There is some debate over the format of the date shown, whether it's MM-DD-YYYY or DD-MM-YYYY last I read.
Just to be clear, these maps have zero to do with your navigation maps. They simply tell the vehicle if the road they are on is handsfree or not.
PV2EV
So will the feature subscription be for new maps, as they are time-bombed?
lancersrock
Kody
USA - IA
Field Engineer
I might be misunderstanding you but blue cruise already Requires a subscription to work?
PV2EV
Correct, but how is it controlled? Expiring maps, requiring new ones (via subscription) would be a way to do it. Someone may have more details on the mechanism of the subscription?
lancersrock
Kody
USA - IA
Field Engineer
I got it now. A map version check would be one of the simpler ways to control it
My 6/30 build has Blue Cruise Map good to 10/12/2022 [dd/mm/yyyy]
