Charges to 100% despite 1x-max set to 90%
lookout
Tennessee
F150 Lightning Lariat
I've found I need to stay up late or get up early to manually stop my charging. I'm using the Ford travel charger at home. I've tried setting the One-Time Max Charge Limit to 90% before plugging in as well as after, but it still charges to 100%. I'd like it to charge to 90% each time When I'm home instead of manually limiting it each charge. Any ideas?
First pic from charge wcreen showing 1x setting
Second pic from app showing charging status
Ford F-150 Lightning Charges to 100% despite 1x-max set to 90% 20221129_165010
Ford F-150 Lightning Charges to 100% despite 1x-max set to 90% Screenshot_20221129_170727_FordPass
EdRudy
Ed
Springfield, VA
Create a location then edit the location and set charge limit to 90%. I created a location and named it Home, then set the limit. Works like a champ.
Make sure you have selected “Use charge settings” and not “Charge when plugged in.” The latter ignores all settings.
Also note the One-Time Max Charge limit relates to when you are plugged into a DCFC, I've used that setting to force stop my EA fast charge activity to 80% rather than the default 90%
Don't mess with that switch when you are AC Basic charging on a mobile or charge station pro, etc
According to the manual, one-time limit is supposed to work on L2 AC charging as well.
If I ever get my truck, I’ll test it. ?
lookout
Tennessee
I had already done that
. Still charges to 100%...
Ford F-150 Lightning Charges to 100% despite 1x-max set to 90% 2022-11-3005.39.091618758688726662378
1) Have you verified the setting from post #3?
2) Check your nav and see if the car really thinks it’s home when you’re home.
Womps
Sid
Lacombe, Alberta
2021 Ford F 150 & 2022 Mustang Mach E
Make sure on your Ford App you are clicked on “use preferred charge settings”. If you are clicked on “charge when plugged in“ it will charge to 100%.
Ford F-150 Lightning Charges to 100% despite 1x-max set to 90% 9DBE3FD7-F36E-4A61-8908-5DBB8CD40648
I'll check that later this week.
Still think the one time switch and the basic home rule though having matching values may be causing OP's problem
@lookout
Once you have finished with the truck, shut off, then turn on to accessory mode, then turn off again, the second round of off will cause the drivers display to show the up coming charging rule to be followed when you plug in. Hopefully you will see your preferred rule and not charge immediately to 100%
lookout
Tennessee
Thank you. Will approach my dealer with this - and the long list of other issues. Black screen, clicking sound, chiped paint from dealer (they notated), etc.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! Can you send us a private message with your VIN and dealership info? I'd like to see how I can help.
EVben
Ben
MN
Lightning, Ranger
I have the same issue and I caught it red handed tonight
“target charge level” being displayed correctly but ignored
Ford F-150 Lightning Charges to 100% despite 1x-max set to 90% 1670400739856
I’ll try using preferred setting next but that will require me to delete my schedule. I had tried this last night after seeing this thread but still had my charge times loaded so it faulted due to some other issues I must be having with the FMC
am I correct in understanding you can’t have both a scheduled charging configuration and a “charge when plugged in” limit as two options to pick between? Seems that way
You chose one or the other below the listed address.
I've noticed that the app lacks details regarding weekend portion of scheduling which you can see in the truck on the Sync Charging screen, for that reason I prefer to make upcoming schedule changes in the truck instead of the app.
