F150 Lightning Audio Builds (Anybody Done One?) Why Not?
We always remove the grille, but we do this every day on these trucks, so our comfort level is higher. Glad you used the perfect tweeter :)We are still working on a alternative solution for different tweeters, hopefully soon we will have something
You all are helpful and great to share the advice and videos you do. Thank you.
Is the insulation behind the back seat the same in the Lightning as it is in the ICE for 2021/2022? Have you confirmed that your new stealth behind the seat box will fit in the Lightning without modification to the trucks back wall insulation?
SoundsGoodStereo
Gold Sponsor
Don
Mount Juliet, TN
soundsgoodstereo.com
F-150
You're welcome. The back wall insulation has to be cut to fit the enclosure except on the SuperCab trucks where the seat does not move into the rear wall. We tested the sound difference and with our enclosure, it acts as a noise barrier, so it works out.
Regarding fitment, we need a customer to test fit or bring us their Lightning to check. From everything that we know and see, it is the same regarding layout.
kvasiir
San Jose, CA
2022 F-150 Lightning Lariat Rapid Red
My kit's on order, so I'll be sure to share results when it gets here.... happen to have any shipping updates for me? ;-)
SoundsGoodStereo
Gold Sponsor
Don
Mount Juliet, TN
F-150
Awesome! No exact shipping date yet
I wish I were a bit closer I'd be there.
SoundsGoodStereo
Gold Sponsor
Don
Mount Juliet, TN
F-150
Greased Lightning
Steve
Hawaii
F150 Lightning Lariat
So I picked up my truck today after having the sound components installed. Bellow is a list of everything.
Initial thoughts are that the Nav TV is prob the way to go over theJL fix 86. When I picked it up the front components were painfully loud in comparison to everything else. I went back and forth between center Chanel (stock) connected or not. Ultimately, I went with the center speaker connected. I was able to tweak the settings on the amp and crossovers and get the soundstage nice and full and balanced. The reason I think the nav tv is probably better is there are still sub frequencies missing. The fix is able to flatten everything out, but it can’t flatten what isn’t there. I had the same subs and amp with the JL fix in another truck just a few weeks ago, so listening to the same songs I'm able to tell the frequencies aren’t there. Before I scrap the JL fix and put in the nav tv I and going to mess with the JL EQ and see if that helps. Ultimately, the stock B&O amp has some really unfortunate DSP effects and the only way to get a full even sound (it seems) is to remove it from the equation completely.
Ill report back after messing with the EQ.
P.S. the JL fix is able to be calibrated at any volume level and I suspect that the shop calibrated it a higher volume where the stock amp is limiting frequencies more. So if it was originally calibrated at 25 calibrating at 15 may find some of those lost frequencies.
Kicker 47KSS6904 Car Audio 6x9... https://www.amazon.com/dp/B084HL82KK?ref=ppx_pop_mob_ap_share
Kicker 47KSC6504 Car Audio 6 1/2"... https://www.amazon.com/dp/B084HL3RL9?ref=ppx_pop_mob_ap_share
Pioneer GM-D9705 Class-D 5-Channel Amplifier with Wired Bass Boost Remote https://a.co/d/iZ8shqC
PIONEER TS-A3000LS4 12" Shallow-Mount Subwoofer with 1,500 Watts Max. Power https://a.co/d/d35BXmk (x2)
https://www.crutchfield.com/p_13698103/JL-Audio-FiX-86.htmli
kvasiir
San Jose, CA
I checked in with SGS today:
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? Screenshot 2022-12-29 at 7.18.08 PM
Sounds like it might be a while yet...
  • Sad
ragj1976
Ok here we go. Just started tonight running some 4ga. See some picks. Drivers side down into frame. Then pop out under drivers feet into the grommet.
stay in between brake Resivour and coolant resivour to avoid steering yoke.
I double techflexed the 2 runs .
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 3F36DAC2-02E1-4363-8AFC-FCE5BBB6AB7A
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 29508A98-ECBC-4E6C-9765-8CDB691D522B
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? F4FE4C1F-8428-4801-A9B4-9E0D85C64974
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 19810038-00B7-4032-806C-CCF4D2FD3FA1
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 26D06258-AD94-47A1-9C15-9CDD45D3AB1F
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 312CF5A4-4F77-40D7-AEA9-1A22ED1F9CB5
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? C9AED09D-3D7F-465E-9A1A-E90DF13DCD8D
  • Love
Already a great idea - I've got to go back and document mine. I already was thinking about a reroute and I was curious how you had access in there, I didn't think to even take the cowling off on the drives side for easier routing in that area. I will likely work on mine a bit and add some documentation.
Thanks for sharing !
ragj1976
Here are some more pictures. Running 2 runs of 4 GA is really thick coming up under that carpet. I managed to get everything back but it is tight.
That other small cable is a 2 conductor 16 ga for the led emblem. Running that as a test, as the fuse box hook up messes with the radio reception.
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? FE3E5A13-A15C-4DF4-9A67-8E8B9BFBD393
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? C43E232B-064F-44C6-A425-8D13CBBB6620
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 54002889-E732-4954-AC3D-B014DBEE6F7A
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? AB1FA1ED-CF73-4C28-9B7E-520B9CB1C153
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 08D96170-FE19-4517-85B8-D26DE131406B
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 3F35B554-CC24-43BD-8625-8C745D0882D7
Ford F-150 Lightning F150 Lightning Audio Builds (Anybody Done One?) Why Not? 5AFC0F4D-FEE6-432F-BD32-A1DE4C5F7740
MichaelCA
'22 Lighting ER, '22 Tesla Model 3, '16 Mustang GT
Man, the f150 lightning 8 speaker setup is prob one of the best Ive heard in a vehicle. What music do you guys listen to requiring a setup upgrade?
Greased Lightning
Steve
Hawaii
I listen to mostly hip hop, but seriously thought “let’s see if I just listen to different music am I happy with this system.” I tried jam bands, folk music, 90s rock. It’s all missing something.
I think about songs I’ve heard on the radio and thought the lyrics said one thing and then I listen to the same song on a proper stereo system and can clearly hear the correct words. That’s part of the difference.
Also, think about all the songs people love and sing incorrectly. Thats due to crappy sound systems.
Elton John “Tiny Dancer” aka Tony Danza
AC/DC Dirty Deeds Done Dirt Cheep and people hearing thunder jeep
Nirvana Smells Like Teen Spirit… Here we are now, in containers (lol).
The 8 speaker b&o system lacks clarity, volume, and a full and balanced soundstage.
I'd almost have to ask what you've listened to previously that you are comparing to? Find someone in your area that has upgraded and listen to some good music you'll hear things you've never heard before.
I will say - is it worth it to many? Llikely not, and that is OK, but listen to a good sound system and you'll then question why this system is so weak for what you are paying.
ragj1976
I'm from the age of left right stereo, not everything coming from the center of the dash. IMO the 8 speaker is so center heavy. Lacks and sub bass. and frankly is not loud at max volume.
That being said, my ears may be suspect as in my teens and 20's I drove around with 4 12"'s in the trunk and a Punch 200.
