Tonneau Range Savings? ~10%?
shadycoh
tx
2021 F150 xlt
wishful thinking is a powerful thing.
Capertrj
Ricky
Maine
2010 F150
I would think any slight increase in aerodynamics would be offset by the 50ish lb cover. I got the retrax pro xr on Black Friday. Have about 1500 miles before installed cover. Now that it’s colder it’s hard to do a fair comparison. Either way on my typical 55 mile one way commute I’m in the 2.0-2.2 kwm before and after.
AdmiralYamo
Chicago, IL
Honda Accord V6 EX-L 2015
I think it's fair to say no one would notice a 5% change in MPG when on a normal driving route without truly controlling a lot of the experiment.
queuewho
Western PA
22 F150 Lightning Lariat SR
Any aero increase would probably be negated by the added weight. I think at very least we should be happy if it is a wash, as having a covered bed that you can use for more than just dirt or something, is very worth it.
Beaux
Georgia
2015 F150 Platinum, 2021 F150 Limited
Having had a Retrax pro MX cover most of the time I've owned the truck I would say I'm not seeing any gains at all.
heelyeah
Tripp
NC
21 Bronco; 22 F150 Lightning; 21 Jeep JT (wife's)
Definitely no observed gains for me, but that's not why I have it.
Jer
Jer
Oklahoma
‘23 Lightning Lariat,‘21 Bronco, ‘17 F350, ‘76 K20
Would think that if a cover added 10% efficiency then Ford would sell every truck with it as standard. That is 20 to 30 miles of range added for pennies. Didn't they add heated seats as standard in the Pro to minimize heat use and make winter range better?
If not as a standard at least recommend a cover if it truly improves range/mileage. I would buy one for a 10% improvement, but don’t think it exists.
Akbrian
Alaska
F150 Lightning 2022
Let see….
Bed cover 1000$ this is cheap for a good one.
Power 0.10$/kwh I know it varies a lot.
10000kwh for 1000$
So let say you use 500Kw a month driving and see a whopping 10% energy savings(impossible) it would only take you 16 years to break even. A more realistic number is 1% so by the year 2200 you could have that tonneau start to pay you back.
So you've never voted or been to, like, any kind of church then, huh?
Neither of your comparisons compare to scientific evidence from testing done by reputable organizations, that show no advantage.
trev5150
Trev
Pilot of pilotless things
I'm talking about hope as a plan.
Ford F-150 Lightning Tonneau Range Savings?  ~10%? stripes-francis-francis
Oh, I get it. "I hope my tonneau cover gets me 10% better miles per kilowatt hour". Got it... :rolleyes:
skyak
F250, 911, Lightning
Probably going to depend a lot on cover surface material (flexible/rigid/smooth/corrugated) and color.
