Nick503955
- First Name
- Nick
- Aug 31, 2022
- San Diego, CA
- 2023 Ford Lightning Lariat, 2024 Kia EV9
Your videos are detailed and insightful, so it's an easy share.Thanks for posting. I was going to put it up later today but you beat me to it. I'll be making at least one more video in the future showing a simulated power outage and me using the system.
Makes sense. From my layman perspective, I was hoping the standard would call for a wall connector that only back feeds when there is grid power, similar to most net metering solar setups.Problem with V2G is there aren't any utilities that have consumer-level programs ready yet, just small pilot programs. Wallbox has the Qusar 2 coming soon and I'm supposed to test one out in the spring.
Not sure 80-amp chargers will have a big uptake. Lucid and Porsche just released their own units, though and I plan to get those soon.
The current Ford system uses an D/C to A/C converter that is part of the home integration system vs. using the trucks onboard inverter which is the limit.Is there a reason why we can't push out as much power as the truck can take in? Why is it limited to 9kW instead of the full 19kW that it can pull?
Interesting choice by Ford to make the $5k special on par with the $1500 solution. Thank you.The current Ford system uses an D/C to A/C converter that is part of the home integration system vs. using the trucks onboard inverter which is the limit.
I doubt Ford is even making any money on this. It is expensive equipment and the R&D must have been a lot also. It's the first of its kind. Future iterations will likely cost less and offer more. That's always the case with new tech.Interesting choice by Ford to make the $5k special on par with the $1500 solution. Thank you.
Hey Tom, thanks for the video! It was super detailed and interesting! I'm getting my 1000 dollar solution installed tomorrow.Thanks for posting. I was going to put it up later today but you beat me to it. I'll be making at least one more video in the future showing a simulated power outage and me using the system.
True, I guess I'm just a little too excited about the possibilities and want all of it nowI doubt Ford is aven making any money on this. It is expensive equipment and the R&D must have been a lot also. It's the first of its kind. Future iterations will likely cost less and offer more. That's always the case with new tech.
Pro Power Onboard is a great feature - and it came with the truck, so...Hey Tom, thanks for the video! It was super detailed and interesting! I'm getting my 1000 dollar solution installed tomorrow.
Unrelated question - did your wireless Android Auto problems go away? I got my truck a couple weeks ago and I have the same phone as you. It has connected every single time perfectly. Hopefully that's your experience as well now.
I still think it's a great system and a good solution for some people - particularly those that aren't as cost-sensitive as most are. But I have to be honest to my followers - my honesty is really all I have when I'm competing for views with others online, and if there's a comparable solution for much less money, I have to mention it.True, I guess I'm just a little too excited about the possibilities and want all of it now![]()
