ElectroJames
- First Name
- James
- Aug 19, 2023
- Springfield, Mo
- 2023 Ford F150 Lightning
- Occupation
- Retired Master Electrician
Hi, to preface my background is as a former master electrician/solar installer, I did this, install myself and purposefully tried to keep all of my wiring behind the wall to limit the amount of surface mount conduit‘s to the equipment.. Currently I am the CTO for a start up solar product. So troubleshooting is natural to me, but this feels more like a software issue.
I installed my intelligent back up system, and I have had nothing but unreliability, glitches, issues and it feels like it comes back to either an issue with the truck or communication between it and the pro charger.
Yesterday, through the FordPass app, I noticed it said the intelligent power couldn’t function because of a fault inside of the truck. This morning when I went to leave, my main odometer display was blank so I couldn’t tell how fast I would be going, I disconnected the battery and reconnected it that worked however then the frunk wouldn’t close so I manually closed it. And in that process of resetting by disconnecting the battery, the “truck fault” alert on my FordPass app did disappear, so I thought what better time to try another utility outage simulation…
Funny enough after waiting around for about 4 mins 2.5x the normal time it did transfer power, but then it kicked back off after 15 seconds and gave an option on the truck display to “start” the power transfer which never worked.
Ever since installing the intelligent backup system I have gotten it to work roughly 5% of the time in simulated utility power outages. Every thing else has been failed attempts.
Dear Ford, please have one of your software engineers reach out, I would really like to understand more of the software digital handshakes and see if we can simplify this and speed up the transfer. Sometimes less is more. At the end of the day I have a really expensive back up power system installed on my house that does not function, and it is kind of upsetting to have spent this much money on something that doesn’t work. At the end of the day I have a really expensive back up power system installed on my house that does not function, and it is kind of upsetting to have spent this much money on something that doesn’t work.
