Motor power is reduced from 100% as battery gets lower
JustaProGuy
MI
Lightning
Has anyone else noticed that as of maybe Sunday 1/15, that when the battery percentage hits around 45% or so the max motor power begins to be reduced. Ie on mine it went down to 95% and continues to decrease as the battery goes lower. Cycling on and off does nothing. Once it's charged again, it goes back to 100% power.
Update: Well I guess I must have missed it all this time, I swear it always said 100% before, even though I did notice lower acceleration when miles got down to like 20 left.
Ford F-150 Lightning Motor power is reduced from 100% as battery gets lower PXL_20230117_213432288
Completely normal. Low battery and cold weather will reduce available power.
JustaProGuy
MI
Lightning
But I've never seen the graphic on the instrument cluster showing a reduction of power for the motors. Unless Ford was doing it the whole time and not displaying it.
I see it all the time after my truck sits in the cold for 12 hours while at work.
JustaProGuy
MI
Lightning
Alright weird I never saw but I guess I must've missed it all this time. I'll update this post
This was my truck last Saturday, freezing, 8% SOC, 55% power limitation to the motors.
I almost never see this limiter except when it is cold and my SOC is under 50%.
Ford F-150 Lightning Motor power is reduced from 100% as battery gets lower 1674057604048
JustaProGuy
MI
Lightning
I just don't ever remember seeing it until a couple days ago. I was getting limited with 41 degrees out, seems like overkill.
