Ford Charge Station Pro finally arrived!
bewbie
NYC
As the title states, it has arrived after a short 6 weeks of owning the truck. I did a quick search and couldnt find any information on the white plastic cover on the front of the charger. It came in the box not fastened and it seems to be a series of cleats the snap the white cover into the black charger. I havent gave it much force, but it doesnt seem to want to clip in. Anyone have this problem? I am trying to figure this out quickly because if its broken, Ill need to contact sunrun for a replacement.
Michael
BMW X5, BMW 528, Porsche 928
Sales Leader
6 weeks? eek. After speaking with Sunrun on Wed, mine will supposedly be in the mail shortly...we will see.
Monkey
Somewhere in the mountains
Mine was delivered 2 weeks to the day of taking delivery of my truck...
Still in the box until I have all the necessary electrical work done. Need panel and service upgrade and a nasty long wire run for a new sub panel in the garage. Ugh...
I remember it taking a bit of force to get it to both clip and unclip. I would just make sure everything looks lined up and that the clips and holes are intact before starting.
Amps
Bolt
This happened to someone else on the forums. It was difficult getting a replacement cover and I'm not sure what the eventual outcome was. Based on the travails the other poster detailed between sunrun and Ford and 'cosmetic damage', I would call and report concealed shipping damage and try to get a unit swap.
davehu
hot springs, AR
glad I ordered a mobile charger. intended to be a backup but glad I will have it if SunRun delays my FCSP
The Install guide on page 7 talks about opening the cover and on page 16 about replacing the cover - it unsnaps via "Hand Pulls" so maybe that info helps? The image of snaping bakc on shows where to push:
"The unit can be left in box to protect from any
scratches or debris. Using both hands, Place
thumbs on inner Black Cover and fingers into Hand
Pulls located on sides of unit to unsnap and
remove the decorative cover and place aside. DO
NOT PLACE COVER FACE DOWN ON ANY ABRASIVE
SURFACES."
Ford F-150 Lightning Ford Charge Station Pro finally arrived! 1706717509563
Good luck!
