Charge Now Option
tigertas32
Kevin
San Diego
2020 Ford Explorer ST
So, I have the lightning setup to charge during certain hours (12a-6a San Diego SDGE). There are times when I want to start charging immediately when I plug in. Currently, I have to go into the app and change the charging from “use preferred charging” to “charge when plugged in”. It’s a pain in the ass plus it changes the settings and I have to change it back after charging. Is there an easy button to do this where it just overrides for this one charge?
Also, I just had a Solaredge EV charger installed. They have a charge now button on their app. But I think because the lightning is set to charge during certain times, it won’t allow the charge to work.
I would just like the ability to set the appropriate times for low rates with the ability to quickly charge when I want without changing settings.
Thanks in advance.
Tomwilli2025
Alabama
Sales
Mine doesn't work that way. I do have to go to the app but at the bottom of the home screen, I click the plugged in waiting to charge. I then select charge to 100%. I do have to watch it if I don't want to charge to 100%. FYI, I'm using the FCSP.
tigertas32
Kevin
San Diego
I also have that button. I haven’t tried it yet because I don’t want to charge to 100%. I will try it later to see if that button does allow to charge now (but to 100%)
Gewalt
Socal
23 Pro (no options)
My e-Golf had hard buttons next to the charge port to force delayed charging or immediate charging and they were instrumental in taking advantage of opportunistic charging while keeping those TOU schedules in.
Every other EV I've owned since has been disappointing in that regard. If Ford can enable that functionality with a specific sequence of pressing of the lock release button that would be amazing.
Ford F-150 Lightning Charge Now Option Screenshot_20230125-074247
Thanks in advance.
There is no Charge Now button, except the Charge to 100%. You can use that, and then resume the schedule if you manually go back in and check to see if your target charge has been reached, or exceeded.
You are correct that a charger will not override the vehicle and make it charge. However, you can override the vehicle and NOT let it charge by setting hours. For example, if you set a departure time outside your 12 - 6AM hours, your vehicle will pull juice UNLESS you set the same 12 - 6AM hours in the charger. Then, if you really want to use power for your departure time, you'd need to click "Charge Now" on the charger and it will provide electricity for the departure setting, assuming it stays in the Charge Now state long enough.
If I want to Charge Now, I do that on my charger and then hit Charge to 100%, then set a timer to go back and stop it.
tigertas32
Kevin
San Diego
@Gewalt I had the egolf too and this was great.
@RickLightning Seems like a lot of stuff to do when a simple override, charge now is easy. Maybe I'm wrong.
I could easily just let the charger do the work, but I have another charger on the other side of the garage that is not internet connected, so I need the truck to have a schedule depending on where my wife parks first.
Come on Ford.
