Coolbreeze704
- First Name
- Bruce
- May 20, 2021
- Troutman NC
- 2024 F150 Flash - 2024 Tesla Model Y LR
- Occupation
- General Manager - Factory Select Homes
So the last time my Ford Pass connected to the Lightning was 2/10. I called Ford and they took me through several troubleshooting steps and determined it was a known issue and that a update should be coming by the end of Feb to fix this. Was told to just keep connected to the home WIFI to make sure I received the update.
Got home and double checked to make sure I was still connected to my home WIFI. It connected with no issue when I first set it up in January. Well got home and checked and it was not connecting. Called Ford and they tried trouble shooting the issue with no luck. Was told I most likely have a bad chip.
Anyone else have this issue? I would also recommend everyone check their trucks to make sure your truck is still connecting to your home WIFI as I had no warning it was dropped and not connected.
Ford also told me I have not had an update since I purchased on 1/13/23. Does anyone know if there have been any over the air updates since mid Jan.?
