Change speedometer from MPH to KMH?
bellyer
Chicago
2021 Mach-E FE & 2023 F-150 Lightning Lariat ER
I am in the middle of a road trip from Chicago to Cooperstown, New York and we took the scenic route up through Canada. I have changed the Measurement Units setting to "km & km/kwh", but the speedometer has remained in MPH, even though all other measurements have flipped to km. Does anyone know how to change the speedometer?
Welcome to Canada! As a Canadian owner, I can select mph right on the instrument cluster options.
bellyer
Chicago
Thanks, I guess I will look through there as soon as I'm done charging at Electrify Canada.
BTW, I am so glad to have found this Electrify Canada before running out of charge. The Ivy fast charging stop I had planned to use that was rated at 100 kw had capped out at 30 kw and then kept turning off after like two minutes of charging. Nice to know charging seems to be as hit or miss here in Canada as it is in the States... ?
Calvin H-C
Calvin
Not only that, but we get charged by the minute, so those slower chargers not only cost you more in time, but you get the privilege of paying more money for energy as well! ?
