Water sloshing, passenger side #2
kendotelie
Tampa, FL
2023 Lariat ER
Hello. I'm in month #3 of owning the F150 Lariat, and I currently have on order a part thats supposed to fix an issue with an fault with the cab pro power system. This problem 3-4 weeks ago
Until today I had not made the connection that this issue may be related to water i have discovered today that is leaking into the cab from around the front passenger side door. The carpet is wet and I can very clearly hear water sloshing on the right side. I have heard this sloshing for a couple weeks now but assumed I had a bottle of water lodged somewhere. This is not the case. The water sounds like it's in the door and I even thought maybe underneath the cab (possibly battery compartment) but there are no clogs in the door. And now having found this water....
@Ford Motor Company for visibility
Ford F-150 Lightning Water sloshing, passenger side #2 20230831_140639
Ford F-150 Lightning Water sloshing, passenger side #2 20230831_140613
Do you have a moonroof?
EdRudy
Ed
Springfield, VA
First thing I would have your dealer check is the drain line coming down the A pillar. They have been known to pop loose from the moonroof frame.
kendotelie
Tampa, FL
2023 Lariat ER
dont those drain line issues usually result in visible leaks into the cab like from the a pillar grip.
That may be where the water is settling. There was a previous post about a lightning that had a frame seam leak behind the passenger fake charging door causing water to pool on the passenger side floor, similar to yours.
https://www.f150lightningforum.com/forum/threads/water-sloshing-passenger-side.14566/
yea thats why i called this thread #2 ;)
i cant get my dealer to check this out until Tuesday. Im wondering if i should go ahead and clean it up or deal with the sloshing water for another few days
Not necessarily. There's also the possibility that the seam sealer by the upper part of the windshield could be the culprit. It's where the DOP and roof are welded together.
kendotelie
Tampa, FL
2023 Lariat ER
so i just had my son take a hose to the top of the cab while I checked from inside I can see the water draining into moonroof and a steady trail of water coming north of the cable channel on the floor, passenger side, from behind the glove
Ford F-150 Lightning Water sloshing, passenger side #2 20230831_171501
kendotelie
Tampa, FL
2023 Lariat ER
more testing this am. the leak isnt occuring from the moonroof, or A pillar. I took the hose to the windshield where it meets the cowl vent and after a few seconds, the water started to trickle in. I believe theres a hole behind the fuse panel on the passenger side thats below the glove box
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there, I'd be happy to look into your Lightning concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
kendotelie
Tampa, FL
2023 Lariat ER
Thank you. I have already sent a DM.
Update: as of Tuesday 9/5, the Lightning is at the dealer. The advisor says they'll need to replace the carpet due to rapid mold growth. They state that it's at the body shop to identify the seam that's open and weld it. ETA is 2-3 weeks.
kendotelie
Tampa, FL
2023 Lariat ER
Update 9/27
No word from the dealership on the repair.
I contacted @Ford Motor Company via their customer service and submitted a buyback request, and submitted a claim via the Ford BBB autoline
