Spill in cup holder
lakeguy55
New Hampshire
2023 Lightning Lariat, 2011 F-150, 98 Expedition
I had a passenger who spilt a cup of coffee into the front cup holders. Before we could grab tissues to soak it up, a significant amount drained down the hole under the rearmost cup holder. You know, the one where you also program another key fob if desired. Anyone know what's under there (other than now coffee)? The hole appears to be designed as a drain, and I'm certainly hoping they have accounted for liquid/water spillage into these.
Shining a light down there doesn't reveal much. I'm hoping it just eventually drains down over the top of the battery box or some other sealed component and onto the road?
There are wires down there. If memory serves the carpet goes all the way under the console. You might consider taking the cupholders out to inspect and clean. That's what I would do but I'm very particular. I'm guessing most people would call it good and forget about it. That's probably the right answer.
I'm surprised, I didn't think there was a hole at the bottom. There is a lift up rubber piece that lets you get to the fob location, but a hole at the bottom, hmm...
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Whammy Bar
Feels to me that if there's a drain... a drain hose should be routing said fluids out of the cabin under the vehicle, not into a concealed area.
I'd be pulling my console apart if I was OP (so my truck doesn't have a latte air freshener smell for the remainder of its life on hot days)
lakeguy55
New Hampshire
Here's a picture of the hole.
Thanks for the link to the other thread. Looks like I may be able to access under there more easily than I thought. Thankfully, just black coffee. But as others have stated, I'll still get in there to clean up. I was hoping someone was going to tell me there is a drain there.
Ford F-150 Lightning Spill in cup holder 1702333247741
I'm thinking about putting a dab of silicon over that hole!
There is no drain. There is carpet and wiring harnesses. I don't have a picture of the carpet.
Ford F-150 Lightning Spill in cup holder 1000023953
Ford F-150 Lightning Spill in cup holder 1000023951
designthis
NYS
2023 F150 Lightning Lariat SR Black 8/21/23 blend
Builder
Before you use silicone, I’d recommend some waterproof tape. If you know a carpenter, grab a little Zip tape from him or her. Then if you ever need to use the hole, you could probably just stick the key through it!
Mashedtators
2023 Lariat ER
Just had this happen as well. What did you end up doing with the drain hole?
lakeguy55
New Hampshire
Honestly, I didn't do anything. I determined that probably only a few drops made it down the hole. I forgot about it until you just reminded me. I'm going to put a dab of hot glue in there. Will guard against spills and will be relatively easy to get out if needed.
