PTS/FDRS VIN Check Thread
CypherBlue
Cesar
Austin, Texas
2023 Lightning Lariat ER
Software Engineer
Please let me know about mine, I just bought it and want to see if it is behind on updates. Thank you!
1FT6W1EVXPWG60654
I have to say it's really nice of you to be doing this and checking. If you'd be so kind can you please check mine? It a Sept 23 build and only 1 update so far. Thanks again!
1FT6W1EVXPWG33325
4.2.1.2 was sent to you in February and nothing before or after. Modules pending updates are below:
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712679434868-qr
1FT6W1EV8PWG35106
can you check it all? Thank you very much!
No OTA's recorded yet; truck seems to be talking to the cloud just fine. Pending updates are:
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712679527776-jx
1FT6W1EV0PWG14461
Thanks!!
Last OTA attempts you had were APIM update 23-PU1103-NAT-VCE that was sent twice toward the end of last year but failed due to a software/manifest mismatch. Your last successful OTA was 6.2.0 last October. Pending updates are below.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712679714393-mw
1FT6W1EV1PWG06014
havent seen any updates yet, let me know what you are seeing. Many thanks!
Last OTA you got was 4.2.2.1 in November. Your list is below. I checked with FDRS in your case instead of PTS to make sure you had a certain update showing (the APIM) and you do, so nothing to worry about. Just gotta wait for them to send you the next one.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712680048500-1y
Just got mine this weekend and curious where it’s at 1FTVW1EV4PWG27385
No OTA's yet; your list is below.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712680199026-ux
Appreciate if you can check 1FTVW1EL9PWG51552
Last OTA was 4.2.3.1 just yesterday.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712680285882-zd
1FTVW1EV5PWG02527
Can you please check my VIN?
hope to get SOC on dash software or BC1.4 soon
Due to the nature your question, I checked your truck is PTS and FDRS. Last OTA you got relevant to what you want was 6.4.0. The OTA that gives you soc on the dash is IPC update 6.8.0. You are on the latest Sync version, but not showing any GWM, TCU or APIM updates. It also shows you don't have the IPMA/PSCM updates pending that are only available with FDRS. Did you update the truck yourself at some point?
Please check mine as well 1FT6W1EV0PWG57486
I have had 2 or 3 power up updates, but no sync updates, unless I am confused about that.
I believe I am missing the SOC percent update.
I am connected to my home wifi.
Many thanks!
Same as above, except you are showing a TCU update pending. You will that and possible GWM before the IPC update you are looking gets released for your truck and has a chance to be sent OTA.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712680754646-yz
1FT6W1EVXPWG60654
Sync 23159 is one behind the latest version. Pending updates are below:
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712680975783-m9
CypherBlue
Cesar
Austin, Texas
Software Engineer
Thank you! What do I have to do to make sure the updates are processed? I have it connected to my Wi-Fi, I have the update schdule set to every day at 1am. Does it need to be charging?
broteus7
Irvine, CA
2023 XLT ER Carbonized Gray Metallic
1FT6W1EV0PWG55141
Thank you. Just bought it 2 weeks ago.
There is nothing you can do to get an update sent to you and there is no way to predict when one will be sent to you. It does not need to be charging. OTA's that require the vehicle to be inhibited only depend on your 12v battery for power when installing, so you want to make sure that battery is well charged when one of those updates get sent to you. The other OTA's will install while the vehicle is driving, so 12v charge is not as important for those.
1FT6W1EV0PWG55141
No OTA's yet. Your list is:
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712681786072-is
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
Yes i did, i bought 2 day pass when someone here help to check software and i buy and upgrade
Sad to see newer version isn’t available even with FDRS
Ok, so then you're still up to date.....for now.
rayman852
Ray
Sacramento, CA
F150 Lightning XLT ER
Your car is not reporting any codes that I can tie to your issue. The only thing I see of concern is that your GWM is consistently reporting DTC U2403 citing ethernet failure with the IPC. I am always wary of these types of codes because they are hardware related. It could just be a loose plug somewhere, but I can't tell from what I can see what is causing the issue.
I appreciate you!
Would this code be related to me not getting any updates? Are you able to see when was the last time I got this code?
I appreciate you!
Not all all. Your truck is talking to the cloud just fine. It reports it almost every time you drive it including today.
dugiepts66
Doug
Oakland, CA
'23 F150 Lightning Lariat ER- Azure
Tech
Acquired mine a week ago and looks like I’m behind on software.
1FTVW1EV9PWG26460
ZheWiz
Jack
Central NY State
Database Developer
Please check mine too? Only owned it for a month. Getting weekly updates, but long way to go, I think. Thank you in advance!!
1FT6W1EV7PWG48204
1FTVW1EV9PWG26460
Yea, it's a bit behind. Also missing APIM, GWM, TCU and IPC updates not shown here. Hopefully now that it is being driven, it will touch base with the mothership and you start getting updates sent. Nothing wrong with the truck itself.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712719123204-
1FT6W1EV7PWG48204
OTA 6.1.0 was sent to you earlier today. Next time you start your truck, it will allow the OTA trigger to go to the next step and if all goes well, download and install the update.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712719353926-f
dugiepts66
Doug
Oakland, CA
Tech
Curious your thoughts…should I use and drive as I would, or should I pursue the dongle and force updates?
only thing I feel I’m really missing out on are the ev routing in Apple Maps (new updated iPhone not recognizing car as an ev yet), and update to use Tesla chargers on road trip we’re a couple weeks out from.
