Drive Modes Missing from APIM (Sync 4a)
artificial_airspeed
Fort Worth, Texas
2022 Ford F-150 Lightning | Lariat SR
My drive mode page “Controls” in vehicle settings seems to be missing from the menu. I can no longer see any of the drive modes available to select and I also can’t turn off One Pedal Mode if I need to?
Any ideas?
Ford F-150 Lightning Drive Modes Missing from APIM (Sync 4a) IMG_1863
What it should look like…
Ford F-150 Lightning Drive Modes Missing from APIM (Sync 4a) 1714498192109-t
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Are you sure it just isn’t scrolled off the top of the page? Can you drag the left column down?
IIRC, we've seen this before, ...... need to hunt the thread
I turned up two other threads to the top of this node, they are variations on the theme.
Try rebooting the Sync screen, hold the Volume down and Next Track buttons for ~30 seconds or until you see the screen flash off.
artificial_airspeed
Fort Worth, Texas
Possibly Pertinent Info:
I had an IPMA module update failure via FRDS a few weeks ago. So I had to PMI the IPMA and that caused some issues with BlueCruise activation. Some great folks from this forum helped me out with that and BlueCruise is good now!
That said, I wonder if my IPMA config is incorrect somehow, hiding the Controls Tab: Drive Modes, 1 Pedal Drive, etc. or maybe the APIM config isn’t allowing the tab to show.
Gimme_my_MME
Yes that is almost certainly the cause right there
artificial_airspeed
Fort Worth, Texas
I believe it. My IPMA 706-01-01 was not configured properly which was the root cause of BlueCruise activation issues. So there’s probably something else not configured right that’s blocking drive modes. Needle in a haystack…..
