Plug Will NOT Disengage From FCSP FIXED POST 87
marc_hanna
Marc
Nova Scotia
'23 Lightning Lariat ER; '25 Tesla Model 3; '16 Porsche Macan S; '87 MB 560SL
I tried to see how this would happen on my unit and I think it’s a little easier than you think. If I were in a hurry and I stuck it in there at the wrong angle and too quickly, I think the additional resistance to make it get stuck like that would hardly be noticeable. In my little test, I realized I was dangerously close to recreating the situation, so I stopped. I think it is an honest mistake and a borderline design flaw.
rdr854
Northern Virginia
Thank you
rdr854
Northern Virginia
You're going to need a tamper resistant 5 point torx bit in the range of t10- t15 that has a long reach, conventional bits mount on a 1/4 driver might not reach, you would need a screw driver length version to reach in to the depth these fasteners are seated.
In addition, the screws closest to the charger will be really difficult to access with a bit. Maybe with an Allen style L-wrench but that is one very specific tool. I'm saying the great Harbor Freight doesn't even have that. ?
JRT
Huntsville, AL
Lightning
I tried playing around with mine this morning, I'd have to use some brut force to make it jam like this. I installed mine so it is pretty simple to pull the cover, also the latch on the cover has a clear open in the bottom, so maybe even able to twist the removed cover and use a thin long screw driver to push to up the latchat the same time.
I hope they help you out but this is for sure some user error, which happens.
There's no space to use a bit on the screws nearest to the charger. Maybe you could use a wrench with one.?
1/4" ratchet wrench at the hex end of the torx driver?
Removing 5 of the 6 might be just enough to get the locking lever out of position.
Sneakypetie78
Pete
Marina del Rey, CA
2023 F-150 lightning Lariat
General Contractor
Except good luck finding another charger that'll pump out 80A. That's how this is unique, and comes (came) free with ER batteries. This is a clear case of bad user error, and not common.
That is what I used - my hex wrench set came with an extension, it was even magnetic which was nice to hold the Torx screws as I pulled them out of the cavites (only a couple need the extension). I already had a Torx set when I had to screw around with some other things.
It is a T20 Torx head you need for the FCSP cover.
EDIT: seems to be smaller than a T5 for the handle - my set only goes to T5 and it is too big...it is so small I can't really even tell if it is a Torx or a star or what.
Good points...
But....
I got my FCSP new in the box from someone selling it on eBay for $600 with tax so about 1/2 the list price.
I will not be charging at 80A, I can't right now because I currently have an SR battery limited to 40-something or other amps, but I wanted the FCSP for the home integration, when the price is right.
The current $10k or so price is not worth it right now, I think the price will come down.
Before anyone flames me for that prediction, I also predicted the Lightning price would come down.
EV battery prices are also coming down as the supply chain readjusts after the COVID reopening,
https://cleantechnica.com/2024/03/18/ev-battery-prices-dropping-a-lot-this-year-next/
My long range plan is home integration with solar (PV).
Functionally, the circuitry is basically a control module, an inverter and a transfer switch.
This is a diagram of the SunRun version without the photovoltaic circuits (solar) (or other battery storage - except a dark start 12v battery) connected.
Ford F-150 Lightning Plug Will NOT Disengage From FCSP FIXED POST 87 Integration System CSP-SunRun wiring
So far I haven't seen any other EVSE's that doubles as a home integration battery backup interface.
In the mean time (before I jump on a home integration system) I will use the 240V 30A out from the Lightning bed via a Generac neutral switching transfer switch in case of an outage with just the basic house circuits connected (as I did with my gasoline generator and my old transfer switch).
If a better EVSE with home integration comes along, that can work with the Lightning, I hope news of it shows up on this forum!
You disassembled the cable head???
Ford F-150 Lightning Plug Will NOT Disengage From FCSP FIXED POST 87 1720462631200-97
