New update (first in a while)
Jif1025
Joshua
Phoenix, Az
2022 Ford F-150 Lightning Platinum Edition
Criminal Lawyer
Hit about 20 minutes ago (8/28)
Ford F-150 Lightning New update (first in a while) IMG_5537
What are the serial numbers at the footer of this message, or as seen on the trucks Sync Screen??
Jif1025
Joshua
Phoenix, Az
Criminal Lawyer
Nothing listed in the app or online. I’ll check the update tab in the truck once I’m done with this hearing.
Mike G
N. AL, USA
So I was looking up something else on PTS and saw this just now (wasn't there earlier this morning)
Ford F-150 Lightning New update (first in a while) Lightning_OTA_Notice_28_Aug-24
And when viewing the details:
Ford F-150 Lightning New update (first in a while) Lightning_OTA_Notice_detail_28_Aug-24
Zero byte file size? And Wi-Fi is necessary? :unsure:
FDRS doesn't show anything right now, but then again I haven't actually gone out to the truck to connect and run a network scan (it might actually show up then). We'll see.
Jif1025
Joshua
Phoenix, Az
Criminal Lawyer
Nothing listed on the sync either- photo below. I was fully up to date prior, to the best of my knowledge.
Ford F-150 Lightning New update (first in a while) imag
F150ROD
U.S. Navy Retired
Nothing here for my 22. Maybe I should go drive around. Last update was March 27th Refined Audio.
The 23-PU113-UNX-DC TCU connectivity update is the same way. 0 byte size because all it did was change the config in one location, so I think it is safe to assume this does the same thing. That was the first OTA I ever saw that said wifi was required.
duncanmaio
Duncan
Norwood, MA
I got this one this afternoon - perhaps coincidentally, it started downloading immediately after I reconnected the truck to the wifi here at work.
Mike G
N. AL, USA
I'm out at the truck now connected up. FDRS still only says I have a TRM update available and the GVMS blocks are still there for the powertrain...but the Check Updates screen says it's downloading the update (truck is on house Wi-Fi right now as well).
Don't have any idea how long the download is...it might have already concluded for all I know, since it never actually says when it's finished downloading.
Mike G
N. AL, USA
So having checked PTS again, I guess I can shut the truck down since it looks like the OTA is ready to launch.
Ford F-150 Lightning New update (first in a while) Lightning_OTA_Notice_detail2_28_Aug-24
After checking PTS again after shutting down it says it was successful and was listed as "FIRE-PRD-SOFTWARE-FNV2" for the gateway.
Not sure if it was as much an update as it was a test to see if my truck was 'paying attention'. :rolleyes:
No files were harmed during this update apparently.
Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
F150ROD
U.S. Navy Retired
Went out for a drive
Ford F-150 Lightning New update (first in a while) IMG_2926
