Class Action Lawsuit - Home Integration System
Runaway Tractor
Yes
o get back on topic though, I am not sure a class action suit is viable or warranted at this point. You just need to have the current system software for all components.
Which nobody at Ford is making any effort to implement in a timely manner. This disaster of a system has been sold and installed since 2022, and they're just not getting around to maybe giving some people a software update that may make it work better. "You might need to spend 3 years begging for someone to do something to maybe make it work" was not part of the deal.
tearitupsports
Russell
Cypress, TX
I don't disagree with you. The system should have been flawless from first delivery.
The issue is that a product not working as expected is probably not going to win a case. You would actually have to be harmed in order to make a class action suit viable. Only those who lost food or income, or health during a power outage where the HIS failed to do its job would likely have a case. Just having a system, that is now fixed for free (regardless of how you feel about the process) it likely not enough.
I personally have a stronger case than most, because I lost power for 5 days back in May, and was not able to use my PPO due to my truck being in the dealer shop for a bad battery module (this was before having the HIS system). I lost some food etc, although I certainly was not financially harmed more than a small claims court case, and even that would be a stretch.
Until people die in their sleep because of a failed HIS system causing their medical devices to stop working, it is going to be a stretch.
I would prefer to help people get their systems working and make it better for everyone.
Runaway Tractor
Yes
That's the problem. It's not fixed. Maybe yours is. But everyone else who bought a think and demonstrates that it doesn't work absolutely has grounds for a suite. The loss is you paying $10,000 for parts and labor for product that is defective and does not work as advertised. This is further substantiated by Ford and Sunrun literally telling their customers "yeah it doesn't work and we don't know why, sorry, bye."
tearitupsports
Russell
Cypress, TX
I am trying to understand if you actually have an HIS and if you would like it working. I think there are plenty of people here who would be glad to help including myself. Yes maybe Ford and Sunrun can't get their **** together, but we can. Delta is not the issue unless there was a straight up installation error with wiring.
Runaway Tractor
Yes
I don't have a HIS because I read about what a dysfunctional and unreliable mess it is before spending the money on it. I want a HIS, but I'm not paying for a dysfunctional and unreliable system that may or may not ever work. For the sake of discussion, lets say your firmware update totally fixes everything (doubtful to be accurate). There is no way to even assure I will get that firmware update because Ford's OTA system is a similar mess.
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
As I have a HIS that has been non functional 98% of the time, and having just gone through hurricane Milton and the tornados that caused tremendous power issues... I bought the system so I would have a whole house "generator" and not have to go out in blinding rain, raging winds, park the truck halfway inside and outside of the garage within a few feet of the FCSP and manually pair the truck to the FCSP while all this is happening to provide power to my house... I bought the system where they showed the truck in the driveway a distance from the house, the power going off and the power coming on automatically as they are preaching safety and security. That is what I was sold... That is what I expect to have recieved. Now saying all that, if they get it working SOON all sins are forgiven and forgotten, but they need to get it fixed. It really is that simple....
Jim Lewis
San Antonio, TX
I really like what you wrote, but if possible, I think having the truck entirely within the garage during a storm would be a better option (maybe you mean the halfway in/halfway out option just for pairing, not BPT?). I worked hard to make mine fit in my garage. It just barely does. Especially in Florida's heat in the summer sun, sheltering your truck entirely in a garage might be good for the EV battery, too. The driveway outside our garage in San Antonio has a southern exposure, and the truck would roast between the driveway heat and the heat reflected off the brick garage walls if I left mine out during July and August here. My FCSP is within a few feet of the left rear passenger door. If FCSP distance is really a problem, maybe the best thing to do would be to move the FCSP location so it's at least in line with the rear seats. My system will work (sorta) with the right rear passenger seat up, all doors and windows closed, a variety of BT devices on in the vicinity, and the left rear passenger door directly in front of the FCSP, a few feet away. Hope the fix comes SOON to us all to make the system ALWAYS work fully automatically, as the initial Ford ads trumpeted-and as you rightly pointed out, Ford has utterly failed to deliver.
tearitupsports
Russell
Cypress, TX
Sorry that it is not working great for you. On my system I can park the truck fully in the driveway (although I have not tested with the garage door closed). I will also say that my charge station pro is just inside the garage by the door as well. I have not had to do anything else crazy like put the seat down or open the windows, etc. I intend to have the truck fully in the garage under power outage conditions.
I will say that I don't think there is any reason why you would ever have to re-pair the bluetooth, or cycle power to any device (other than the truck itself). After a lot of testing and figuring things out, I am fairly confident that the FCSP and delta pieces are not the actual culprit in systems not working. I am quite sure it is the truck modem. For the people who get their systems working after letting the CSP sit for 24 hours, etc. I believe it is actually the truck resetting after that time that is getting the systems to work.
With the recent updates, I no longer have any issue except when the truck modem is out. The truck modem has plenty of other symptoms to identify it as well. I also believe after recent updates, the truck modem issue is from using the sync Alexa app primarily.
What software of the truck, FCSP, and Delta inverter are you on? I think we can get your system a lot more reliable without Ford, Sunrun, etc.
darknla
gerar6
Hacienda Heights
F-150L XLT SR
I am also having issue with mine. I can not get it to work. The best thing it does, is it sends power to the inverter and wont send power to the main panel (house). I just got ECG-24.2.5.6.2.2 updated this week. Do you know if ECG-24.2.5.6.2.2 will update the Bluetooth firmware?
Ford F-150 Lightning Class Action Lawsuit - Home Integration System Screenshot_20240912-151708_M Professional (1)
Ford F-150 Lightning Class Action Lawsuit - Home Integration System Screenshot_20240912-175905_M Professional (1)
tearitupsports
Russell
Cypress, TX
I believe there is no issue with the Delta portion of the system. It looks like it is working properly.
Is it at the latest firmware?
The transfer does take about a minute or so to initiate.
Has the system ever worked?
What is the status light of the charge station pro? I assume it is solid green.
What is the status light of the charge port status ring on the truck? Is it white or green?
What does the intelligent backup app show (a screenshot would be useful)?
How close is the charge station to the truck?
I am not sure exactly what update fixed mine as I got 2 of them between it not working and being successful. I do know that 6.14 was one of those 2 I received. I think ECG-24.2.5.6.2 could have been the other one, but not certain.
darknla
gerar6
Hacienda Heights
F-150L XLT SR
Is it at the latest firmware? If your asking about the inverter, yes.
What is the status light of the charge station pro? I assume it is solid green. Yes
What is the status light of the charge port status ring on the truck? Is it white or green? Green
I sometime have to the the unlocking trick
What does the intelligent backup app show (a screenshot would be useful)? I don't have that app is it different from the Charge Station Pro, or the Ford Pass app
How close is the charge station to the truck? Pretty close, there is line of site from the back seat to the charger.
Ford F-150 Lightning Class Action Lawsuit - Home Integration System Screenshot_20241016-161739_M Professional
tearitupsports
Russell
Cypress, TX
Has the system ever worked correctly sending power to the loads?
If the truck and charge station pro are both blinking green, then the truck should be sending power. The intelligent power app is in the truck on the main screen. I will attach a screenshot below. It will verify the power transfer.
If the truck sends power but the inverter isn't sending further to your backup panelboard, I would think you either have a communication error on RS-485 lines, or your transfer switch WHB200 isn't being seen by the inverter. You aren't turning off a breaker or disconnect between the inverter and WHB are you?
Again it makes a difference if this has ever worked or not.
Ford F-150 Lightning Class Action Lawsuit - Home Integration System IMG_1995
darknla
gerar6
Hacienda Heights
F-150L XLT SR
It has never worked, I just turn off the main breaker to test it no other switches.
Ford F-150 Lightning Class Action Lawsuit - Home Integration System IMG_20240916_122258696_HDR
tearitupsports
Russell
Cypress, TX
Well the great news is that the truck to charge station is working, and that is typically where most people have issues.
The bad news is that it is most likely a wiring issue...who installed the system and what is your level of comfort trying to diagnose electrical yourself?
The setup should be main panel -> Whole home backup (WHB200) -> secondary panel board -> inverter. I have a suspicion something in that sequence is incorrect. For instance do you think a 5kW load on your critical load panel is correct? That seems like a lot to me.
A lot of this is going to require taking off covers and tracing wires. Something you should not do if you are not familiar with it.
darknla
gerar6
Hacienda Heights
F-150L XLT SR
I don't have a critical load panel, it's going straight to the main panel done by a license electrician. He double checked the wiring yesterday from the Delta diagram. I will be showing this thread to my electrician.
