Balance point for 2-post lift?
Squeeps
Shane
2023 F-150 Lightning Pro
USMC
Hello all
Looking to get my truck up on a 2 post lift. There is rent-a-bay garage near me, and they will put the truck on the lift for me (liability reasons I'm sure).
My concern is that I believe the lightning f/r weight balance is much different than the gas trucks. The lifts have a graphic on them, that they go by, showing how far forward to pull the vehicle by a reference point on the floor. My concern is that by going by the default "truck under WB X" guidance, too much weight will end up on the rear of the lift.
If anyone has put these trucks on a 2 post themselves, how much does it differ from the ICE verson? To clarify, I understand where the jack points are on the frame: I'm referring to placement of the truck forward and back to achieve safe balance.
If I'm worrying about a whole lot of nothing, feel free to make fun of me below. Thanks
I don’t know for sure, but there are 4 distinct jack points. I can’t imagine anything other than using them would work. Their location is shown in the manual.
Squeeps
Squeeps
Shane
USMC
I'm not suggesting the use of alternative jack points. The arms of the 2 post can extend and swivel, allowing you to reach the jack points with the truck pulled in almost any which-way
Just a matter of how far forward or back to pull the truck, before extending the arms to the manual prescribed jack points
Gotcha….I misunderstood the assignment! ?
Ventorum94
FL
Chev Avalanche, BMW 550i, Tesla MY, Tesla M3
Mechanical Engineer
One of the defining characteristics of EVs, including our Lightnings, is their near-perfect F/R weight distribution, thanks to the mass and location of the battery pack, and the relatively lightweight drivetrain components (also a very low center of gravity!).
Squeeps
Squeeps
Shane
USMC
This might help.
SOURCE
This certainly confirms the weight distribution!
I'm no physicist but I take it to mean then that on a 2 post lift, the posts should be perfectly centered between the axles?
Squeeps
Squeeps
Shane
USMC
I can't say I've noticed much difference in the handling department vs my 2022 gasser f-150, but it certainly bounces the bed around less on washboard dirt roads. This may also be a function of independent rear suspension
This certainly confirms the wright distribution!
I'd say park the truck with center point between axles in line with posts, then position the lift arms so they land at the Ford designated lift points.
xwing
Okeana, OH
Hello all
I have had mine up on my lift for tire rotation. I pull forward so the lift arms can reach the arrows on the frame designated as lift points. Attached is a pic that will give you an idea.
-Jeff
Ford F-150 Lightning Balance point for 2-post lift? PXL_20230520_183414388
