Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
Also note that updates, both in FDRS and OTA, are specific to vehicle model year. 22s don't have the Sync 1270 update available anymore, and only a tiny handful of people got it if they used FDRS right when it came out, but 23s and 24s continue to get it via both FDRS with the right equipment and OTA.
Ford's update process is abysmal.
Jasin
Jasin
2022 Lightning ER Lariat
So even if I get the VCM cable, FDRS license, and learn the process I still cannot update my '22 to Sync 1270 to get the Updated Google Map integration...
Warp Asylum
Austin, TX
Unless something has changed in the past 2 weeks or so since I updated mine, that is correct.
Until Ford makes it available for 22s again, all we can do is wait.
Jasin
Jasin
Looks like Mike G did Nov 27...so maybe. I am asking around to see if anyone I know in my area has the equipment before I buy it
PJnc284
Garner, NC
He probably updated it as soon as it popped up for the 22's since they're usually still a bit rare when he installed them so I'm guessing he's had the updated APIM for some time. :cwl: If you PM him your vin, he can check what modules you have showing with updates available in FDRS. I believe @rugedraw is/at least was offering out loaner mongooses but there's probably a waiting list and you'd still need a power supply.
Warp Asylum
Austin, TX
Yeah, Mike updated his truck back in October in the short window from when it came out to when they pulled it. You can see his posts about it in the other FDRS thread.
Jasin
Jasin
Oh the post I saw must have been a quote or something I thought his post was on the 27th
Warp Asylum
Austin, TX
That post was him telling someone else what was available for their 23.
Jasin
Jasin
Ahh ok...dang
Having the tools to perform the updates is half the battle. The other half is has Ford released the necessary update(s) for your vehicle. Based on the Sync version you're currently on, if a VIN check reveals you have a pending update for the GWM or TCU, chances are that once those updates are installed, the APIM will/should release once those are done. If a VIN check reveals you have a pending APIM update, then that is the one you're looking for.
Warp Asylum
Austin, TX
You can check my VIN if you want (I can PM it to you), but when Mike checked mine in October, it showed the APIM update available (and I already had 6.14 at that time). Then when I updated my truck over Thanksgiving weekend, the APIM update was no longer available. I updated everything except the BCM which we can't do without a dealer login. At some point it was pulled for mine and most likely other 22s.
There's some suspicion that it might be sequenced behind the BCM update but I don't think anyone has been able to confirm that yet.
Jasin
Jasin
Thank you for that info:
Once I find someone that can scan I will see if there is anything pending for GWM and/or TCU. If not then how about APIM.
Appreciate the help
BCM will not prevent the APIM from releasing. Just messaged you.....you do have an APIM pending.
Appreciate the help
Send me the VIN and I can check.
Jasin
Jasin
Sent. Thanks
Newton
WA State
I don’t see how an update could be approved for dealer install without being approved for OTA (unless it didn’t work over the air for some reason). If the update is not safe then it is not safe whether it comes from a dealer or over the air.
I guess I just have a bad feeling about this, it seems like every truck has a different combination of software. The plus of buying a mass-market product is that there are millions of people with an identical product so you really can form a good idea of how well it will work and what situations to avoid. If every truck is basically running hand built software then I could easily have the only truck where Version 23.1 of one module conflicts with version 15.3 of another and the brakes stop working if I turn on Sirius XM.
