Ionna Rechargeries
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Ionna is a new joint venture between 8 car makers including GM, Mercedes, Hyundai, Kia, Stellantis, Honda, Toyota, and BMW. When they announced the startup in February they said they planned to roll out 30,000 chargers by 2030. At the time is sounded like a stretch but after attending the soft opening of their first location on Thursday they just might pull it off.
Ionna is branding their sites “Rechargeries” and the first location is in Apex, NC. Apex is a formerly small town that is now a suburb of Raleigh. The Apex site is located in an old gas station near the downtown area. They have installed 5 Alpitronic 400kW units, each equipped with two ports. These units are capable of 1000V up to 600A on each cable so they are better at power sharing than units that are current limited. I shared a charger with a Hummer and since I was close to 80% I was only pulling about 80 kW and he was able to pull about 250 kW. When I unplugged he went up to about 275. There are 4 NACS cables and 6 CCS. They are located under a canopy but there aren’t any pull throughs.
On Thursday they partnered with Kyle Conner’s Out of Spec group to host a Cars & Coffee. Part of the goal was to stress test the site so they had people sign up for 20 minute charge sessions. They charged 2 cents a kWh so that they could test the whole system all the way through the back end payment processing. They kept all 10 stalls full for the whole 5 hours and they probably charged around 150 vehicles. It seemed to go flawlessly except for about 10 minutes when one charger went down. The Ionna and Alpitronic folks jumped on it and after a reset it came back online. It was apparently heat related.
The charging experience was awesome. They plan to have an app in the future but for now you pay on a credit card terminal just like a gas station. There is a charging detail screen that lists all the relevant charge parameters and displays a charge curve. They are plug and charge capable but so far it only works with BMW and Mercedes (if I remember correctly). Hopefully Ford will work with them to add them to the Blue Oval network. The cables are very long but their cable management system is the best I’ve seen. The cable is supported from above which takes most of the weight off. If you need extra length an arm swings out. You can take the cable across the vehicle and it will be held in the air, not touching your truck. I could reach the charge port on the Lightning from either side of the charger, whether I backed in or pulled in forward.
The old gas station building has been converted into a lounge. The building was a traditional mid-20th century service station. There is an office section and then two service bays with garage doors. The office section has been turned into a lounge with vending machines and seating and a set of restrooms. It will be open 24 hours a day. The service bay has a counter that will be operated by a local bakery offering sandwiches, pastries, and coffee. There is additional seating in this area plus two small conference rooms that you can reserve to work in. There is also a video game machine on the wall that has a bunch of retro games like Pac-Man and Galaga. Ionna plans to partner with local operators to do something similar in most of their sites. The service bay area will be open during normal business hours. The old canopy where there were 2 pumps is still there and they have additional outdoor seating there. It’s possible they could add a pull through charger in that area in the future.
They broke ground on this site just over two months ago and plan to go live on 12/27. Apex was one of the original 6 sites and after the event they announced that 4 additional sites were already under construction. These guys aren‘t messing around like EA does. They have also partnered with Sheetz to build at least 50 sites. I’m looking forward to seeing these pop up along the highway.
I made a short video located here: Here are some images from the day.
Ford F-150 Lightning Ionna Rechargeries IMG_0597
Ford F-150 Lightning Ionna Rechargeries IMG_1122
Ford F-150 Lightning Ionna Rechargeries IMG_1129
Ford F-150 Lightning Ionna Rechargeries IMG_1128
Ford F-150 Lightning Ionna Rechargeries IMG_1126
Ford F-150 Lightning Ionna Rechargeries IMG_1130
Ford F-150 Lightning Ionna Rechargeries IMG_1120
B177y
Olympic Peninsula, WA
It's awesome to see projects like this finally happening! I wish them nothing but success and hope to see more "rechargeries" all across the US. I love travelling in my Lightning but more charging availability is absolutely necessary, especially to make towing and travelling off of interstate highways truly viable. Thank you for sharing.
PJnc284
Garner, NC
Had something come up last minute and couldn't make it but looked like a good time. Sad I missed @tommolog's Pizza buffet. :crackup: Will be curious to see how viable the Apex location is as it's away from i-40/95 so it'll get mostly local traffic unless you happen to be traveling on US64/1 or 540.
carys98
carys98
Cary
Raleigh, NC
Retired EE
I think the Apex site is more of a corporate lab. It’s only a few miles from their headquarters so they can try things there and it’s a quick trip if they want to observe or need to tweak something. They are starting one in Garner at an old 76 station just off I40 and I think that one will be more typical.
Ford F-150 Lightning Ionna Rechargeries IMG_0609
Scorpio3d
SS/IBA car wash owner
Very cool!
thanks for sharing!
Interesting how they marked the CCS spots I assume the NACS are marked as well!
I wish I could fill up for .02/kwh
carys98
carys98
Cary
Raleigh, NC
Retired EE
Very cool!
thanks for sharing!
Yep, the NACS spots are clearly marked.
potato
BC, Canada
2023 F150 Lightning XLT ER
Bit of a difference from some existing CCS chargers. I have charged where it's literally out back of a Canadian Tire right beside the dumpsters. And of course no amenities... having toilets available would be amazing; the rest is icing on the cake
Reactions: N87
Danface
Dan
Central Mass
2023 Lightning XLT
Charging at a location setup for charging AND for the drivers that's fast and friendly ... huh, who the hell needs that?
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
Watched the whole out of spec video and it all looked nice.. Lots of comments on how this will work so far from an interstate... Locations like this are becoming the wave of the future... We just had FPL (Florida Power and Light) just install 2 400Kw units .3 miles outside our development right on US 1... Mike's from the interchange but perfect for day tripping and having a place to charge when you get there... Similar in concept, located right outside a Duncan Donuts and near "destination" spots... FPL locations aren't covered and the cables are heavy, but they are committed to putting in locations like this everywhere they can so you don't have to go to an interstate to charge.. proof of the need was as soon as it was opened I have watched it and it has very regular use... .30 a kilowatt doesn't hurt for fast charging either...
kstype
Kurt
Pennsylvania
Principle Systems Engineer
It was a great time at the Ionna event! Sharing some pics…
Ford F-150 Lightning Ionna Rechargeries IMG_3022
Ford F-150 Lightning Ionna Rechargeries IMG_3033
Ford F-150 Lightning Ionna Rechargeries IMG_3034
Ford F-150 Lightning Ionna Rechargeries IMG_0616
Ford F-150 Lightning Ionna Rechargeries IMG_0557
Ford F-150 Lightning Ionna Rechargeries IMG_0605
Ford F-150 Lightning Ionna Rechargeries IMG_3039
Ford F-150 Lightning Ionna Rechargeries IMG_3061
Ford F-150 Lightning Ionna Rechargeries IMG_3063
carys98
carys98
Cary
Raleigh, NC
Retired EE
I put together a map of the locations they've announced so far. I also found a copy of a site plan someone put on Plugshare for one of the locations. It looks like an old gas station that may have been repurposed to handle CNG. That one is more typical for the type of station they will be building. It has a canopy with two islands and they show 6 chargers where the gas pumps would have been. It will be easy to pull through those sites. There is one additional charger set up as a parking space with handicap marking. It is located right along I-70.
https://www.google.com/maps/d/edit?mid=1oN5JXWCOmpdaBlLV1U2RJklRPjtOyS8&usp=sharing
Ford F-150 Lightning Ionna Rechargeries 1440318
3rdgenfan
Geoff
Delaware
Cybersecurity
Got an alert on facebook that they're opening the Scranton PA location this Friday; not sure I feel like doing 5 hours of driving but I've done worse for car meets.
They are opening 2 in Ohio. Will make a nice road trip when they open.
carys98
carys98
Cary
Raleigh, NC
Retired EE
The Northeast and Mid-Atlantic Lightning clubs are going to have some folks there. A few of them were in Apex last week. I checked and it would be a 10 hour trip for me. Maybe if it was summer.
