AZT9
Peoria, AZ
I didn't notice a difference at night between 10% or 100% when I did mine.
It does in fact work but what we were thinking was the DRL being the lightbar is incorrect, the DRL values that are changing are actually
The light in the middle
Of the top and bottom headlights. The lightbar does not get any brighter than it is unfortunately.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_8665
21st Century Truck
Martin
I tested last night after setting the DRL's back to 10% and no one flashed their highbeams at me. Seems to have worked. I don't think the DRL's were blinding anyone, I think it gave the impression my highbeams were on and I wasn't dimming them.
Yeah I think that on our Lightnings the DRLs (at least on my trim) are the small rectangular lights in between the top and bottom LED projectors in each headlight. Makes sense that when their brightness is increased they would appear as small high beams, especially when cresting a small rise on the road.
PJnc284
Garner, NC
I didn't notice a difference in those either a while back when I tried it. Left was 10% and right 100%
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2024-10-03 195945
21st Century Truck
Martin
Haha I just wrote a post about the same thing.
AZT9
Peoria, AZ
It didn’t “take” right the first time I attempted it too but it is 100% the light that those values are changing
Thank you for the research! I have updated post 1.
In general I find overly bright running lights to be worse than many lights. Above the cutoff there is surprisingly little light, maybe a lux or three at 200 feet. But that is a focused beam. The running light being unfocused, diffuse, makes the brightness to other drivers increase rapidly
SpaceEVDriver
Arizona
Could I respectfully make a suggestion for the first post? I know it will be a bit of work to do this, but if you hide the specifics of each modification under a Spoiler tag, it will keep that first post cleaner and easier to read for someone looking for a specific modification.
Example for the first several modifications:
only works on the front windows because one-touch is not enabled in the back windows.
DDM 740-06-02 xxxx xxxx 01--
PDM 741-06-02 xxxx xxxx 01--
DDM 740-06-03 01xx xxxx xx--
PDM 741-06-03 01xx xxxx xx--
BCM 726-11-02 xx01 xx01 xx--
BCM 726-22-01 xxxx xxxx 01--
BCM 726-22-02 xxxx xxxx 01--
APIM 7D0-09-01 xxxx xExx xx—
Or Use Easy Mode from this post
The swiveling (dynamic bending) lights continue to work with these settings. May take a couple of restarts to take effect. Settings were adapted from this F150gen14 ICE forum thread.
APIM 7D0-09-01 x1xx xxxx xx--
APIM 7D0-09-03 xxCx xxxx xx--
IPMA 706-01-01 xxxx xxx9 xx--
SCCM 724-04-01 xxx4 xxxx xx--
HCM 734-01-02 xxxx x2xx xx-
HCM 734-03-02 xxxx xxx1 x1--
HCM 734-11-01 0735 89
IPC 720-01-01 xx8x xxxx xx--
IPC 720-10-01 xxxx xxx3 xx--
@FlasherZ Notes here to check to make sure there aren't any checksum DTC's set for the HCM.
Creates a SYNC toggle to turn on/off Silent Mode. See this post for more info.
BCM 726-25-02 0101 0101 01xx
BCM 726-28-02 01xx xxxx xx
APIM 7D0-09-02 Dxxx xxxx xx- Assumes current value is "C". If "E", change to "F".
Added a mod to enable Silent Mode. This is sometimes referred to Dark mode, Police mode, campground mode, etc. However there is a difference between true Dark Mode and Silent Mode (hint: dark mode is too dark!). See this post on the ICE forum. Also thanks to @SpaceEVDriver for his post here.
This will enable a toggle on Sync so you can turn this on/off easily:
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1735840881600-e9
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1735840923711-0h
You can also use "easy mode". Under APIM and BdyCM search for "silent" and enable all options as shown in the screenshots here:
APIM:
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1735841376205-h7
BdyCM:
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1735841465650-t2
The first line is the same as changing 726-28-02 to "01". The remaining 5 lines match each "01" in 726-25-02.
SpaceEVDriver
Arizona
Not possible for an astronomer! ;)
astrand1
Alex
Studio truck driver
I didn’t either, but apparently, oncoming traffic seems to have noticed. If I still get highbeam flashes from oncoming traffic I will assume Glare Free is the culprit.
It should not be. I’ve never had anyone flash me with glare free enabled for the last 4 months. I’m betting it’s the DRLs.
astrand1
Alex
Studio truck driver
In regards to the Lincoln auto folding mirrors. Do the puddle lights work now? That was an issue in the ice f150s that if you enabled it then puddle lights did not work.
Vancouver, Canada
2023 F150 Lightning Lariat ER
Removes black box on reverse camera that says "full view not available"
APIM 7D0-02-02 xxx* xxxx xx-- If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7 Note: reset APIM after the change
Some of the mods in the spreadsheet below work on the lightning, some don't or have to be altered in some way. Be careful.
Source: Livnitup's spreadsheet from post 1 in this thread.
Thanks for the camera one. I'll check it out. The spreadsheet you embedded looks like Livinup's. I posted a link to it in post 1. I always vet each mod against that spreadsheet. Many of the parameter bytes can control 4 functions (e.g. "F" = binary "1111") so you can't willy-nilly change to one specific value. I take that into account and where applicable give instruction on what the value should be based on the current value so you don't inadvertently lose functionality.
