Does Ford allow download of full charging history?
grange
david
23 Ford Lightning
On my Ford app I can see the last 6-8 weeks worth of charging (logs). Is there anyway to download a complete csv or xls of all my charging history?
I am trying to find something while using my Chromebook and nothing? I am hoping there is a historical record somewhere?
NO, start a spreadsheet and manually log the information, that's what I do.
grange
david
23 Ford Lightning
Figured. Ford is clueless when it comes to the App and/or digital experience. They get many things right.....but the simple ideas around an EV are totally missed.
SpaceEVDriver
Arizona
I also wish the OBD data included a total kWh used PID, but I haven't been able to find one.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
In addition I also log my updates on that same spreadsheet, just in case the Ford records crash ...
Also, the todate "trip records" shown in the truck erased at 10,000 miles, so I now log that data once a month or so, it helps remind me what my actual efficiency is so I can look for changes.
SpaceEVDriver
Arizona
Yubbs
@024 F-150 Lightning Lariat
I have an app called EEVEE. It’s not free and will only give you info starting when you set up the app going forward but it’s pretty useful
Heybucket
MB
NorCal
2023 Lariat ER
Does it also reset the avg? I’ve kept trip 1 since I got truck and see that miles roll over but does it still keep avg or does it really matter since I didn’t reset? I’ve been at 2.2 kWh pretty much whole time. but that’s mostly hilly suburbs with occasional roadtrip/ highways
Just got back from a 2000 mile road trip and avg 1.8 on trip out and 2.0 on way back. But took a different route so not apples to apples.
davehu
hot springs, AR
If you have an FCSP, from Ford Pass you can connect to it and it does have a complete history. sort by cost or kwhr and by day, month, or year. Of course it only is recording home charging, not DCFC's. can't download either.
mr.Magoo
2022 Lariat ER, AMB
There is one for total/accumulated throughput in Ah, I can dig it up tomorrow.
HYBAT_LIFE_CHRG
0x22485D
tmpValue = parseInt(vResponse[3] + vResponse[4], 16);
Not sure how this translates to Torque or CarScanner, but it's the same as all the other 16bit values, no conversion needed and it gives you the throughput in Ah (my graph converts it to kAh)
Ford F-150 Lightning Does Ford allow download of full charging history? 1735924575972-9o
que o
Danface
Dan
Central Mass
2023 Lightning XLT
@Ford - The early adopters on the this forum are geeks, PROVIDE US DATA! Not the GOM or some little light to show how much KWH is being expended or no charge logs but INFORMATION. You did not build a truck, you built a computer that can be driven.
